查看: 5684|回复: 19
[求助] 求几篇论文,谢谢各位了
发表于 2011-12-28 19:42:26 | 显示全部楼层 |阅读模式
小弟最近在看SAR ADC,在IEEE上找了点论文,可是没有下载权限,请哪位有下载权限的达人帮忙下载,在此谢过了
A non-binary capacitor array calibration circuit with 22-bit accuracy in successive approximation analog-to-digital converters
(http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=1187284)
A 12b 11MS/s successive approximation ADC with two comparators in 0.13μm CMOS
(http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=5205345)
A 10-bit 12-MS/s successive approximation ADC with 1.2-pF input capacitance
(http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=5357202)
A 10-bit 500-KS/s low power SAR ADC with splitting comparator for bio-medical applications
(http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=5357200)
A 12-bit 1MS/s Non-calibrating SAR A/D Converter Based on 90nm CMOS Process
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=5532526
A 12-bit fully differential SAR ADC with dynamic latch comparator for portable physiological monitoring applications
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=6098230
12-bit non-calibrating noise-immune redundant SAR ADC for system-on-a-chip
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=1692885
Novel low-power 12-bit SAR ADC for RFID tags
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=5450523
0.18um low voltage 12-bit successive-approximation-register analog-to-digital converter (SAR ADC)
http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=6111760
发表于 2011-12-28 23:57:34 | 显示全部楼层
A 12b 11MS/s Successive Approximation ADC with two comparators in 0.13μm CMOS俺有,怎么传?
发表于 2011-12-29 02:00:16 | 显示全部楼层
You owe me a bunch, body!
Here you go!
I didn't name it but you should find all in unzipped folder.
发表于 2011-12-29 02:37:54 | 显示全部楼层
SAR ADC.zip (9.95 MB , 下载次数: 202 )
发表于 2011-12-29 08:51:57 | 显示全部楼层
楼上的给力
发表于 2011-12-29 08:55:17 | 显示全部楼层
4#的是好同志啊~
发表于 2011-12-29 14:05:08 | 显示全部楼层
谢谢phdseeker,多谢各位了
 楼主| 发表于 2011-12-30 22:20:51 | 显示全部楼层
非常感谢phdseeker了
发表于 2013-8-28 23:14:50 | 显示全部楼层
ths!
发表于 2013-8-29 08:56:24 | 显示全部楼层
4楼是个好同志
GMT+8, 2025-9-12 02:58 , Processed in 0.021064 second(s), 6 queries , Gzip On, Redis On.
