查看: 2745|回复: 1
[原创] 十分简单的timer,支持多通道,连续计数和握手,复位有效电平,计数周期为参数
发表于 2011-12-23 13:11:13 | 显示全部楼层 |阅读模式
结构十分简单,宏定为为
·define ONES(n) {(n-1){1'b0},1'b1}
data_bits 为clog2的函数,verilog 参考手册上的clog2给仿真用的,综合的话有warnning,对输入做了赋值,使用不太舒服,自己写了一个,宏是重载data bits 的位宽。
module gecko_timer_lite
    parameter TIMER_NUM            = 2'b0                           ,//=== timer channel number,support multi channel
    parameter TIMER_WIDTH          = data_bits(TIMER_NUM)           ,//=== timer number width
    parameter TIMER_CYCLE          = 8'd32                          ,//=== timer output cycle
    parameter TIMER_OPCODE         = 4'b0101
    input                          clk                              ,
    input                          rst_n                            ,
    input  [TIMER_WIDTH-1     : 0] i_timer_restore                  ,//=== timer restore to zero
    input  [TIMER_WIDTH-1     : 0] i_timer_en                       ,//=== timer enable
    input  [TIMER_WIDTH-1     : 0] i_timer_ack                      ,//=== timer interrupt clear
    output [TIMER_WIDTH-1     : 0] o_timer_on                        //=== timer count up and issue interrupt
    //=== opcode[0] = timer self clear and countinus output
    //=== opcode[1] = timer ack clear and output level
    //=== opcode[2] = timer restore active level
    `DATA_BITS ( 16 )
    localparam TIMER_RESTORE_ACITE = TIMER_OPCODE[2]                ;
    localparam TIMER_ACK           = TIMER_OPCODE[1]                ;
    localparam TIMER_MODE          = TIMER_OPCODE[0]                ;
    localparam TIMER_CACHE_ON      = TIMER_OPCODE[3]                ;
    wire   [TIMER_NUM-1       : 0] w_timer_eos_count                ;//=== timer end of counter
    reg    [TIMER_WIDTH-1     : 0] r_timer_counter[TIMER_NUM:0]     ;//=== timer main counter
    generate
    genvar i;
    begin : timer
    for ( i = 0; i < TIMER_NUM; i = i + 1 )
    begin
    always @ ( posedge clk or negedge rst_n )
        if ( ! rst_n )
            r_timer_counter <= `TD 1'b0;
        else if ( i_timer_restore == TIMER_RESTORE_ACITE )
        else if ( w_timer_eos_count == 1'b1 )
        begin
            if ( TIMER_ACK == 1'b0 )
            else if ( i_timer_ack == 1'b1 )
        end
        else if ( i_timer_en == 1'b1 )
            r_timer_counter <= `TD r_timer_counter + `ONES ( TIMER_WIDTH );
        else
    assign w_timer_eos_count = r_timer_counter == TIMER_CYCLE;
    end
    end
    endgenerate
    generate
    genvar j;
    if ( TIMER_CACHE_ON == 1'b1 )
    begin : timer_cache
    reg    [TIMER_NUM-1       : 0] r_timer_cache                    ;//=== timer main counter
    for ( j = 0; j < TIMER_NUM; j = j + 1 )
        if ( ! rst_n )
            r_timer_cache[j] <= `TD 1'b0;
        else
            r_timer_cache[j] <= `TD w_timer_eos_count[j];
    assign o_timer_on               = r_timer_cache                 ;
    end
    else
    begin : timer_uncache
    assign o_timer_on               = w_timer_eos_count             ;
    end
    endgenerate
endmodule
 楼主| 发表于 2011-12-23 13:13:39 | 显示全部楼层
`define DATA_BITS(n_data_width)        \
function [n_data_width-1:0] data_bits                                                              \
        input [n_data_width-1:0] data        \
        integer                   i;        \
        reg [n_data_width-1:0]value;        \
        begin        \
        data_bits = 1;        \
        value = data - 1;        \
        for ( i = 0 ;i < n_data_width-1; i = i + 1 )                                                   \
                if ( value[i] == 1'b1 )        \
                        data_bits = i + 1;        \
        end        \
endfunction //=== calculate data valid bits
GMT+8, 2025-11-2 07:00 , Processed in 0.016307 second(s), 6 queries , Gzip On, Redis On.
