查看: 4485|回复: 4
[求助] 大家帮忙看看我这个DC脚本有什么问题。
发表于 2011-12-8 12:02:07 | 显示全部楼层 |阅读模式
报这个错误:Error: Required argument '-name' was not found (CMD-007)
#_________________________________________________
#set up path and library
set search_path
[list /home/hlcui/lib_path]
set target_library [list fs90a_c_sc_wc.db]
set link_library
[list {*} fs90a_c_sc_wc.db fs90a_c_sc_bc.db]
set symbol_library [list fs90a_c_sc.sdb]
#design entry
analyze -format verilog des_ctrl.v
analyze -format verilog des_cal.v
analyze -format verilog des_top.v
elaborate des_top
current_design des_top
uniquify
check_design
set_wire_load_model
-name G5K
set_wire_load_model enclosed
set_operating_conditions WCCOM
create_clock -period 33 -waveform [list 0 16.5]
-name clock [get_ports clock]
set_clock_latency 2.0 [get_clocks clock]
set_clock_uncertainty -setup 1.0 [get_clocks clock]
set_dont_touch_network [list clock rst]
#input drives
set_driving_cell -lib_cell BUF1 -pin O [all_inputs]
set_drive 0 [list clock rst]
#output load
set_load 1 [all_outputs]
#set input & output delays
set_input_delay 10.0 -clock clock [get_clocks clock] [all_inputs]
set_input_delay -max 25.0 -clock clock [get_clocks clock]
[all_inputs]
set_input_delay -min -2.0 -clock clock
[get_clocks clock]
[all_inputs]
set_output_delay 10.0 -clock clock [get_clocks clock]
[all_outputs]
#___________________________________________________
#compile and write the database
compile
write -hierarchy -output des_top.db
write -format verilog -hierarchy -output des_top.sv
#____________________________________________________
#current reports
report_timing -nworst 50
发表于 2011-12-8 13:15:42 | 显示全部楼层
error是在那行?
 楼主| 发表于 2011-12-8 14:19:00 | 显示全部楼层
回复 2# eagle654321
    如何看错误是在哪行?
发表于 2011-12-11 23:25:05 | 显示全部楼层
关注中
GMT+8, 2025-9-17 17:47 , Processed in 0.015291 second(s), 5 queries , Gzip On, Redis On.
