查看: 3380|回复: 0
[求助] 请教高手一个综合报错的问题!谢谢
发表于 2011-12-7 17:20:52 | 显示全部楼层 |阅读模式
报的错误是:
Error: Required argument '-name' was not found (CMD-007)
Error: Required argument 'port_list' was not found (CMD-007)
Error: Required argument 'port_pin_list' was not found (CMD-007)
脚本如下:
#_________________________________________________
#set up path and library
set search_path
[list /home/hlcui/lib_path]
set target_library [list fs90a_c_sc_wc.db]
set link_library
[list {*} fs90a_c_sc_wc.db fs90a_c_sc_bc.db]
set symbol_library [list fs90a_c_sc.sdb]
#design entry
analyze -format verilog des_ctrl.v
analyze -format verilog des_cal.v
analyze -format verilog des_top.v
elaborate des_top
current_design des_top
uniquify
check_design
set_wire_load_model large_wl
set_wire_load_model enclosed
set_operating_conditions WCCOM
create_clock -period 33 -waveform [list 0 16.5] clock
set_clock_latency 2.0 [get_clocks clock]
set_clock_uncertainty -setup 1.0 [get_clocks clock]
set_dont_touch_network [list clock rst]
#input drives
set_driving_cell -lib_cell BUFFD2 -pin Z
set_drive 0 [list clock rst]
#output load
set_load 1 [all_outputs]
#set input & output delays
set_input_delay 10.0 -clock clock[all_inputs]
set_input_delay -max 25.0 -clock clock [all_inputs]
set_input_delay -min -2.0 -clock clock [all_inputs]
set_output_delay 10.0 -clock clock [all_outputs]
#___________________________________________________
#compile and write the database
compile
write -hierarchy -output des_top.db
write -format verilog -hierarchy -output des_top.sv
#____________________________________________________
#current reports
report_timing -nworst 50
GMT+8, 2025-12-30 10:15 , Processed in 0.013209 second(s), 7 queries , Gzip On, Redis On.
