楼主: dkslc
sentaurus 2010.09安装成功后运行时出现问题,求救各位大侠
发表于 2012-8-22 10:35:14 | 显示全部楼层
回复 20# dkslc
    楼主在吗?加我扣扣709699763,有事请教。多谢
 楼主| 发表于 2012-8-22 11:10:11 | 显示全部楼层
回复 21# weixiaoHUST
需要回答问题才能加好友
发表于 2012-8-22 17:07:38 | 显示全部楼层
回复 22# dkslc
    答案是王倩云,不好意思我给忘了还有问题
发表于 2012-8-29 13:18:38 | 显示全部楼层
回复 1# dkslc
    Just follow steps below and all should be able to work like charms!
(1) The best things about linux is most of the library files can be used in any linux version (ubuntu or redhat or fedora or all of them).
(2) Just google to get the libDF-ISE.so file. (usually it is inside a package files but don't worry, we need that particular file only).
(3) Don't install the whole packaged!
(4) Extract and copy the file into the home directory (in windows, it is called desktop).
(5) Try this command to transfer it into the library directory.
      sudo ln -s linDF-ISE.so /usr/lib/linDF-ISE.so
(6) This requires ROOT password.
(7) Also, ln ====> LN  (not IN, as many people err with this command).
发表于 2012-8-29 13:24:38 | 显示全部楼层
回复 1# dkslc
    In case after the installation, the sprocess still unable to execute with errors, then try below method!
(1) Execute sprocess in the home directory (usually it is called desktop in windows).
(2) Don't execute sprocess inside STDB folder. (Something wrong with the STDB environment)
(3) make sure the file you want to processed (such as diode_fls.cmd) is copied into the home directory also!
(4) After finished execution, just copy it back to the original directory (directory where the file belongs to)
(5) I bet, after sprocess, there will be four more files to copy back to original directory! (Case by case basis)!
 楼主| 发表于 2012-8-29 19:10:26 | 显示全部楼层
回复 25# yapfranky
谢谢你的答复,最终我还是换了系统。
发表于 2013-3-11 17:05:54 | 显示全部楼层
出现一样的问题  楼主最后怎么解决的啊
GMT+8, 2025-12-26 09:12 , Processed in 0.018069 second(s), 5 queries , Gzip On, Redis On.
