查看: 7439|回复: 10
[转贴] How I size my CMOS Level shifter
发表于 2011-11-28 22:50:57 | 显示全部楼层 |阅读模式
Let's say I am using TSMC 180nm I want to convert the incoming level from 1.8 to 2.5 volts, so using Level shifter attached in Figure. Then How can start sizing of this level shifter and how I set frequency ..
发表于 2011-11-29 13:12:36 | 显示全部楼层
MN1,MN2,MP1,MP2用I/O device,
inverter(VDDL)用core device,
length一般选最小;
在IN加上方波(频率为你想要的),跑tran分析,
看输出能否到0/VDDH。
发表于 2011-11-29 13:13:39 | 显示全部楼层
two PMOS(MP1,Mp2) size should be much smaller than NMOS(MN1, MN2)
发表于 2011-11-29 13:16:05 | 显示全部楼层
发表于 2011-11-29 13:26:21 | 显示全部楼层
发表于 2011-11-29 14:11:59 | 显示全部楼层
回复 4# YZX408
nice.right.
 楼主| 发表于 2011-11-30 01:42:58 | 显示全部楼层
Hi,, Thanks ..
But in general mobility of NMOS is greater than PMOS so in this wway the size of PMOS devices should be high than NMOS ...is it..?
发表于 2011-11-30 08:31:11 | 显示全部楼层
你先设定一组参数,跑个仿真看看结果如何。
回复 7# terebin4
发表于 2016-8-24 09:30:59 | 显示全部楼层
谢谢分享
发表于 2018-3-1 08:30:50 | 显示全部楼层
多谢版主解答~~
GMT+8, 2025-9-13 19:00 , Processed in 0.029750 second(s), 7 queries , Gzip On, Redis On.
