查看: 2271|回复: 2
[求助] DC 安装很顺利,但运行不了,请教大家!
发表于 2011-11-25 12:07:04 | 显示全部楼层 |阅读模式
系统是vm wokrstation -- rhel4.6as
这是验证License:
Integrity check report for license file "/home/suzhou/eda/synopsys/license/synopsys.dat".
Report generated on 24-Nov-2011 (SCL_10.9.3)
Checking the integrity of the license file....
Valid SSS feature found.
License file integrity check PASSED!
You may now USE this license file to start your license server.
Please don't edit or manipulate the contents of this license file.
.bashrc文件添加内容为:
#lmgrd
export PATH="/home/suzhou/eda/synopsys/scl/scl_v10.9.3/linux/bin:"$PATH
#start synopsys license using lmgrd
alias lmli2="lmgrd -c /home/suzhou/eda/synopsys/license/synopsys.dat -l ~/syn_lic.log"
setenv VCS_ARCH_OVERRIDE linux
#Design Compiler
export PATH="/home/suzhou/eda/synopsys/dc/dc_2009/bin:"$PATH
#Set Home Directory
export SYNOPSYS="/home/suzhou/eda/synopsys"
export DC_HOME="/home/suzhou/eda/synopsys/dc/dc_2009"
#SNPSLMD_LICENSE_FILE
export SNPSLMD_LICENSE_FILE=27000@localhost
#Alias
alias dc="dc_shell"
alias dv="design_vision"
发表于 2011-11-26 21:46:55 | 显示全部楼层
 楼主| 发表于 2011-11-28 08:09:57 | 显示全部楼层
回复 2# liust
   by command: limi2   ?
GMT+8, 2025-12-20 01:46 , Processed in 0.023195 second(s), 7 queries , Gzip On, Redis On.
