发表于 2013-1-9 22:18:08
显示全部楼层
运行了几次patch,显示这结果,不知道是否patch正确?(REDHAT AS4系统)
[eda@localhost x86_cal_2011.2_16.14]$ ./patch_calibre2011_linux
[total hits/matching patterns/non-matching patterns]
6 errors: failed to read+write: sfk - skipping
6650 files checked, 0 changed.
1 errors occurred.
然后配置.bashrc和生成license.dat,最后[eda@localhost]$calibre -gui
报这样的 :WARNING:calibre 2010.2 and later will require CPUs which support SSE2 instructions.TO disable this check,execute:setenv CALIBRE_DISABLE_SSE2_CHECK YES
我在.bashrc中写了一句set CALIBRE_DISABLE_SSE2_CHECK YES ,然后source了,还是没启动calibre.楼主能告知原因吗?谢谢! |
