楼主: xaut234
[求助] VMware安装synopsys vcs-mx_vD-2009.12出现问题,请高手解答!!!
发表于 2012-3-29 15:37:41 | 显示全部楼层
这个安装还真复杂
发表于 2012-3-29 23:35:08 | 显示全部楼层
Linux version 'Fedora release 16 (Verne)' is not supported on 'x86_64'
  officially, assuming linux compatibility by default. Set VCS_ARCH_OVERRIDE
  to linux or suse32 to override.
  Please refer to release notes for information on supported platforms.
Warning-[LINX_KRNL] Unsupported Linux kernel
  Linux kernel '3.3.0-4.fc16.x86_64' is not supported.
  Supported versions are 2.4* or 2.6*.
Error-[VCS_COM_UNE] Cannot find VCS compiler
  VCS compiler 'VCS_HOME' not found. Environment variable
  /usr/eda/syn/vcsamd64/vcs_2011.1/linux
  (/usr/eda/syn/vcsamd64/vcs_2011.1/linux/bin/vcs1) is selecting a directory
  in which there isn't a compiler 'linux' for a machine of this type
  'VCS_HOME'.
  Please check whether 'VCS_HOME' is incorrect; if not, see below.
  'VCS_HOME'.
  <extra strings were given: <null string> >
Perhaps vcs hasn't been installed for machine of type "linux".
Or the installation has been damaged.
To verify whether vcsE-2011.03 supports machine of type "Linux 3.3.0-4.fc16.x86_64",
please look at ReleaseNotes for more details .
We determine the machine type from uname; maybe uname is incorrect.
You can fix installation problems by reinstalling from CDROM
or downloading it from the Synopsys ftp server.
For assistance, please contact vcs technical support
at vcs_support@synopsys.com or call 1-800-VERILOG
错误,有人帮解答下么?
发表于 2012-8-31 12:53:14 | 显示全部楼层
回复 1# xaut234
Ubuntu系统下Synopsys VCS DC PT安装文件下载及安装破解方法(支持2008,2009,2010,2011版)
http://bbs.eetop.cn/thread-347196-1-1.html
发表于 2012-9-6 20:06:44 | 显示全部楼层
参考学习一下。。。
发表于 2012-10-17 18:31:35 | 显示全部楼层
请使用-full64选项
发表于 2014-4-18 22:18:04 | 显示全部楼层
哦 我试试吧 楼主辛苦了
发表于 2014-4-19 19:40:31 | 显示全部楼层
谢谢楼主
发表于 2014-4-19 21:16:23 | 显示全部楼层
linux版本有问题
发表于 2014-5-29 00:10:32 | 显示全部楼层
谢谢!
发表于 2014-6-3 22:23:40 | 显示全部楼层
a good virtualization approach
GMT+8, 2025-12-30 05:19 , Processed in 0.018608 second(s), 3 queries , Gzip On, Redis On.
