查看: 16501|回复: 22
[求助] VMware安装synopsys vcs-mx_vD-2009.12出现问题,请高手解答!!!
发表于 2011-11-1 22:20:16 | 显示全部楼层 |阅读模式
安装完成后,可以使用VCS命令,但是不能启动DVE,输入DVE,会出现以下报告:
Please check directory permissions.License server does not support feature VT_Visual
This feature has expired, or has not yet started or is
greater than the highest version.
Please contact VCS Customer Support at 1-800-VERILOG for more information.
Failed to obtain license...
Note: Use +vcs+lic+wait ( or -licwait <minute> or -licqueue  in Unified Use Model ) to queue for license
请高手解答呀!!!
 楼主| 发表于 2011-11-1 22:24:02 | 显示全部楼层
这是在.bashrc中的设置
#lmgrd
export PATH="/home/hh/eda/synopsys/scl/scl_v10.9.3/linux/bin:"$PATH
#start synopsys license using lmgrd
alias lmli2="lmgrd -c /home/hh/eda/synopsys/license/synopsys.dat -l ~/syn_lic.log"
#setenv VCS_ARCH_OVERRIDE suse32
export VCS_ARCH_OVERRIDE=linux
#Design Compiler
export PATH="/home/hh/eda/synopsys/dc/dc_2009/bin:"$PATH
#vcs-mx
export PATH="/home/hh/eda/synopsys/vcs/vcs_2009/bin:"$PATH
#dve
export PATH="/home/hh/eda/synopsys/vcs/vcs_2009/gui/dve/bin:"$PATH
#simif
export PATH="/home/hh/eda/synopsys/simif/simif_2009/bin:"$PATH
#pts
export PATH="/home/hh/eda/synopsys/pt/pt_2009/bin:"$PATH
#Set Home Directory
export SYNOPSYS="/home/hh/eda/synopsys"
export DC_HOME="/home/hh/eda/synopsys/dc/dc_2009"
export VCS_HOME="/home/hh/eda/synopsys/vcs/vcs_2009"
export DVE_HOME="/home/hh/eda/synopsys/vcs/vcs_2009/gui/dve"
export SIMIF_HOME="/home/hh/eda/synopsys/simif/simif_2009"
export PT_HOME="/home/hh/eda/synopsys/pt/pt_2009"
#SNPSLMD_LICENSE_FILE
export SNPSLMD_LICENSE_FILE=27000@localhost
#Alias
alias dc="dc_shell"
alias dv="design_vision"
alias vcs="vcs"
alias dve="dve"
alias simif="simif"
alias pt="primetime"
发表于 2011-11-2 09:44:00 | 显示全部楼层
在src文件中增加VT_Visual的feature
 楼主| 发表于 2011-11-2 10:42:44 | 显示全部楼层
回复 3# bingled
    谢谢啊,能不能说的详细点。
发表于 2011-11-3 10:02:50 | 显示全部楼层
使用EFA LicGen 0.4b(没有?坛子里找),在packs文件夹下的synopsys.src文件中增加VT_Visual的feature,生成license(坛子里有教程),再用Synopsys SSS Feature Keygen生成SSS,拷贝文件中的语句到前面的license中(坛子里有教程)。
发表于 2011-11-6 12:07:33 | 显示全部楼层
最后不要用虚拟机吧
发表于 2011-11-13 17:35:46 | 显示全部楼层
最后不要用虚拟机吧
发表于 2011-12-2 20:23:59 | 显示全部楼层
Thanks!
发表于 2012-2-20 22:14:55 | 显示全部楼层
谢谢了
发表于 2012-3-29 15:37:41 | 显示全部楼层
这个安装还真复杂
GMT+8, 2025-12-19 06:49 , Processed in 0.025067 second(s), 5 queries , Gzip On, Redis On.
