查看: 3910|回复: 1
[求助] BUCK电路中续流问题
发表于 2011-10-28 21:26:29 | 显示全部楼层 |阅读模式
3
2
2
1
1
BUCK结构中PWM控制器通常控制两个NMOS,利用占空比来调节输出电压。
我的疑问是:为什么下端的MOS是NMOS?
NMOS的电流方法只能是从漏极到源极,如图中所示。如果说图2和图3中还能利用外部二极管续流的话,那图1如何实现续流呢?
发表于 2011-10-31 12:08:58 | 显示全部楼层
Lateral NMOS has an intrisic body diode from substrate (P-) to drain (N+). Usually this diode is sloppy therefore you need an external Schottky diode to improve switching efficiency, but it will still work even with this external diode.
GMT+8, 2025-12-20 03:56 , Processed in 0.022213 second(s), 8 queries , Gzip On, Redis On.
