楼主: zhq415758192
[讨论] EDI place
发表于 2011-10-31 08:33:15 | 显示全部楼层
楼上2位,可能误解了,所谓设置net weight不是用set_attribute -net -weight来设,这是专门针对routing的设置,针对place的设置应该是specifyNetWeight,试试看就知道了。
发表于 2011-10-31 14:42:40 | 显示全部楼层
NAME
       specifyNetWeight
SYNTAX
              specifyNetWeight
              <netName> <...>
              <netWeightValue>
DESCRIPTION
       Specifies the priority weighting of a net.
       Note:  Partition  pin assignment honors specifyNetWeight. Pins that connect to a net that has a higher net weight are assigned before the pins that con-
       nect to a net with a lower net weight.
       You can use this command after importing the design.
       Parameters
             <..>                                Specifies the name(s) of an individual net.
                                               You can use wildcards (*?) with this parameter.
           <netWeightValue>                      Specifies the weighting priority of the
                                               net name, with values 512 (highest) through 1
                                               (lowest), or 0 (dont care). Default: If you do
                                               not specify this parameter, the weight for nets is
                                               2. Cadence recommends using a value between 1 to
                                               10. The maximum net weight is 512. If you set the
                                               value greater than 512, the value will be set at
                                               512.
       Examples
       The following commands set the priority net weighting for nets STRW to first, WE2N to second, and IOWIN to third:
       specifyNetWeight WE2N 9
好像是 做pin assign用的吧
发表于 2011-10-31 14:53:37 | 显示全部楼层
做个实验就知道,这个feature是管placement的,加上dbGet的TCL语法,我经常用它来模拟ICC的magnetic place。
发表于 2011-10-31 15:07:51 | 显示全部楼层
这样的,
edi有magnet_placement 么, 是通过该方法做的么
发表于 2011-10-31 16:16:45 | 显示全部楼层
EDi没有magnet_placement,只是用脚本模仿而已。
 楼主| 发表于 2011-10-31 23:40:58 | 显示全部楼层
回复 11# hawkz
    大侠经验丰富啊。谢谢!
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 06:32 , Processed in 0.014084 second(s), 3 queries , Gzip On, Redis On.
