查看: 2556|回复: 0
[求助] 加入chipscope出现translate的报错
发表于 2011-10-25 22:32:40 | 显示全部楼层 |阅读模式
再用MIG控制DDR2的时候,没加入chipscope前还可以P&R,但是加入chipscope观察其信号的时候会出现这个错误:
ERRORack:1560 - The register "u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_ctl_io/u_ff_ras_n" has the property
   IOB=FORCE, but was not packed into the OLOGIC component. The output signal
   for register symbol
   u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_ctl_io/u_ff_we_n requires general
   routing.
这个怎么解决呢?去掉程序中的IOB=FORCE这个描述对程序有影响吗
其中程序出错点为:
  // RAS: = 1 at reset
  (* IOB = "FORCE" *) FDCPE u_ff_ras_n
     .Q   (ddr_ras_n),
     .C   (clk0),
     .CE  (1'b1),
     .CLR (1'b0),
     .D   (ras_n_mux),
     .PRE (rst0)
     ) /* synthesis syn_useioff = 1 */;
GMT+8, 2025-12-25 09:39 , Processed in 0.015477 second(s), 7 queries , Gzip On, Redis On.
