查看: 2734|回复: 1
[讨论] 时序分析的一个奇怪问题
发表于 2011-10-18 15:27:07 | 显示全部楼层 |阅读模式
综合的时钟相关脚本如下:
create_clock -period 30 -name OSCX_Clk [get_ports OSCX_CLK]
set_clock_latency -source 1 [get_clocks OSCX_CLK]
set_clock_latency 1 [get_clocks OSCX_CLK]
set_clock_uncertainty 0.5 [get_clocks OSCX_CLK]
set_clock_transition 0.3 [get_clocks OSCX_CLK]
create_generated_clock -name Mcu_Clk -source [get_ports OSCX_CLK] -divide_by 2  [get_pins {clk_gate/Mcu_Clk}]
其中综合完毕时序分析发现有如下违例:
  Path Group: Mcu_Clk
  Path Type: max
  Point                                                   Incr       Path
  clock OSCX_CLK' (rise edge)                            45.00      45.00
  clock network delay (ideal)                             2.00      47.00
  U1/U2/IP_MODULE/PCLK (IP_MODULE)
                                                          0.00      47.00 r
  U1/U2/IP_MODULE/PDOUT[1] (IP_MODULE)
                                                         25.00      72.00 f
  U1/U2/U111/Y (AND2X1)                   0.24      72.24 f
  U1/U2/U52/Y (MXI2X1)                    0.17      72.40 r
  U1/U2/U51/Y (NAND2X1)                   0.10      72.51 f
  U1/U2/OtpDat_reg[1]/D (DFFSXL)          0.00      72.51 f
  data arrival time                                                 72.51
  clock Mcu_Clk (rise edge)                              60.00      60.00
  clock network delay (ideal)                             0.00      60.00
  U1/U2/OtpDat_reg[1]/CK (DFFSXL)         0.00      60.00 r
  library setup time                                     -0.21      59.79
  data required time                                                59.79
  data arrival time                                                -72.51
  slack (VIOLATED)                                                 -12.71
我想不明白为什么在OSCX的上升沿是在45ns,而不是30ns?我觉得它们的关系应该如下图才对啊!
发表于 2011-10-19 13:06:35 | 显示全部楼层
有点奇怪,同问。谢谢
GMT+8, 2025-12-25 21:36 , Processed in 0.017471 second(s), 7 queries , Gzip On, Redis On.
