查看: 7197|回复: 9
[求助] 求助:运行DC时报告system clock has been set back.错误
发表于 2011-10-11 08:37:08 | 显示全部楼层 |阅读模式
详细信息如下:
Unable to obtain feature 'Design-Compiler' because:
Error:Internal licensing error number -88:System clock has been set back.
Feature: Design-Compiler
License path: XX/XX/XX/XX(my license path)
FLEXnet licensing error:-88,147
For further information,refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..(SEC-17)
Fatal: Design-Compiler is not enabled.(DCSH-1)
 楼主| 发表于 2011-10-11 08:39:26 | 显示全部楼层
安装的是200809版的DC,服务器的时间比正常时间晚几个月,不知道问题出在哪里了,困扰啊!!
 楼主| 发表于 2011-10-13 16:19:33 | 显示全部楼层
已解决。
没人回复,大概是因为问题太简单了吧,后面若有人遇到相同问题请联系我,没有的话就当我自娱自乐了,呵呵!
发表于 2012-8-1 22:55:08 | 显示全部楼层
麻烦您告诉一下解决方法,谢谢,我安装Inplan 也出现了这个问题。
发表于 2012-8-23 09:36:55 | 显示全部楼层
回复 3# ck040521
    是什么原因呢?
发表于 2012-12-12 12:46:47 | 显示全部楼层
:handshaek :v
发表于 2013-8-4 10:04:05 | 显示全部楼层
Unable to obtain feature 'Design-Vision ' because:
Error: Internal licensing error number -88: System clock has been set back.
Feature:       Design-Analyzer
License path:  27000@localhost.localdomain
FLEXnet Licensing error:-88,147
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".. (SEC-17)
Unable to obtain feature 'Design-Analyzer ' because:
Fatal: At least one of the following must be enabled : Design-Vision, Design-Ana lyzer. (DCSH-10)
以前DC能正常使用,现在突然出现了同样的问题
发表于 2018-12-3 03:36:59 | 显示全部楼层
怎么解决的啊,我也遇到同样问题
发表于 2018-12-4 14:10:37 | 显示全部楼层
Verdi也会。系统时间改回去,或重装。当前系统时间因某种原因变到安装时间之前了
发表于 2018-12-4 14:42:05 | 显示全部楼层
Linux或windows的系统时间
GMT+8, 2025-12-23 07:19 , Processed in 0.021111 second(s), 7 queries , Gzip On, Redis On.
