查看: 4074|回复: 2
Matlab在运行中经常冒出一大堆javaxxxxx的提示
发表于 2011-9-30 10:16:11 | 显示全部楼层 |阅读模式
matlab的command window中经常刷出一大堆
[ConditionalEventPump] Exception occurred during event dispatching:
java.lang.NullPointerException
at com.mathworks.mlwidgets.explorer.DocumentTableColumns$11.compare(DocumentTableColumns.java:204)
at com.mathworks.mlwidgets.explorer.DocumentTableColumns$11.compare(DocumentTableColumns.java:202)
at com.mathworks.mlwidgets.explorer.DocumentTableUtils$2.compare(DocumentTableUtils.java:59)
at com.mathworks.mlwidgets.explorer.DocumentTableUtils$2.compare(DocumentTableUtils.java:57)
at com.mathworks.mlwidgets.explorer.DocumentTableUtils$1.compare(DocumentTableUtils.java:43)
at com.mathworks.mlwidgets.explorer.DocumentTableUtils$1.compare(DocumentTableUtils.java:36)
at com.mathworks.widgets.grouptable.GroupingTableModel$18.run(GroupingTableModel.java:822)
at com.mathworks.widgets.grouptable.GroupingTableModel$20.run(GroupingTableModel.java:929)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
请问这是什么问题?
发表于 2011-10-8 21:48:51 | 显示全部楼层
一般是内存溢出或者画图的问题了吧。减小数组大小试试。
 楼主| 发表于 2011-11-1 20:43:27 | 显示全部楼层
回复 2# lantian767
不是的,基本上随便一个操作都会冒出一堆这玩意,重装了也没用,准备换个matlab版本看看
GMT+8, 2025-12-28 10:00 , Processed in 0.013135 second(s), 4 queries , Gzip On, Redis On.
