查看: 4722|回复: 3
[求助] max_transition violations when doing signoff STA
发表于 2011-9-28 17:54:46 | 显示全部楼层 |阅读模式
Hi, everyone,
no max_transition violations is reported in ICC, during which stage, min_max corner is used with both max and min tluplus is provided.
however, when doing signoff STA in the Worst corner, lots of max_transition violations are reproted, among which the largest negtative slach is -0.3, and I provided these endpoint to ICC using focal_opt, ending with no success.
and how to fix these problems?
thanks in advance.
发表于 2011-9-29 10:17:07 | 显示全部楼层
the same SDC , ? same  max_fanout/max_transition/max_capacitance constraints ?
icc correlate well with pt ,
for the transition /cap violations the tool can not fix ,
please  fix them manully ,  normally can not clean all of them inside ICC ,
 楼主| 发表于 2011-9-29 13:31:06 | 显示全部楼层
回复 2# icfbicfb
thanks icfbicfb,
yeah, the SDC is the same, however, too many max_transition violations are reported under the WC corner when doing signoff STA, which makes it impossible to fix them manually......
发表于 2011-9-29 13:36:15 | 显示全部楼层
The RC might be slightly different in ICC and PT, can this be the cause?
GMT+8, 2025-12-23 20:43 , Processed in 0.018588 second(s), 5 queries , Gzip On, Redis On.
