查看: 5297|回复: 9
[求助] signoff STA is timing-violation clean, but the post_simulations fails
发表于 2011-9-20 21:21:57 | 显示全部楼层 |阅读模式
Evening, everyone, sincerely hoping for your help for the given troubles:
I have done the signoff STA for my design, for which the result shows no timing violation, however, the post simulations fails. and I have reported the timing_path which shows violations during post_simulation, and found no violations in the STA report.
where does this result from?
given below is the detailed info:
  A.the post simulation log:
    Timing violation in testbench.u_design_1.u_design_top1.u_encodingT.u_tmp.\enc_out_shifter_reg[56]
    $setuphold( posedge CK &&& (vcond2 == 1'b1):3189300120, negedge D:3189300120, limits: (10,10) );
  B.the STA report for the path above
Report : timing
    -path_type full
    -delay_type min
    -max_paths 1
Design : design
Version: E-2010.12-SP3
Date   : Tue Sep 20 21:14:28 2011
  Startpoint: u_design_top1/u_encodingT/u_tmp/enc_out_shifter_reg[56]
               (rising edge-triggered flip-flop clocked by encodingT_clk)
  Endpoint: u_design_top1/u_encodingT/u_tmp/enc_out_shifter_reg[56]
  Path Group: encodingT_clk
  Path Type: min
  Point                                                   Incr       Path
  clock encodingT_clk (rise edge)                        0.00       0.00
  clock network delay (propagated)                        2.90       2.90
  u_design_top1/u_encodingT/u_tmp/enc_out_shifter_reg[56]/CK (SDFPNSRBQQB1)
                                                          0.00       2.90 r
  u_design_top1/u_encodingT/u_tmp/enc_out_shifter_reg[56]/QB (SDFPNSRBQQB1)
                                                          0.57 &     3.47 r
  u_design_top1/u_encodingT/u_tmp/U64/YN (OAI22D1)       0.14 &     3.61 f
  u_design_top1/u_encodingT/u_tmp/enc_out_shifter_reg[56]/D (SDFPNSRBQQB1)
                                                          0.00 &     3.61 f
  data arrival time                                                  3.61
  clock reconvergence pessimism                           0.00       2.90
  clock uncertainty                                       0.60       3.50
        3.50 r
  library hold time                                      -0.19       3.31
  data required time                                                 3.31
  data arrival time                                                 -3.61
  slack (MET)                                                        0.30
plz help, and thanks in advance.
发表于 2011-9-20 22:36:44 | 显示全部楼层
setup的timing呢?
 楼主| 发表于 2011-9-20 23:10:40 | 显示全部楼层
回复 2# optihack
also no setup violations in the signoff STA report.
发表于 2011-9-21 14:53:02 | 显示全部楼层
回复 1# henry_wangjj
    what does the post simulation log mean? It indicates a setup or hold violation?
发表于 2011-9-22 04:13:42 | 显示全部楼层
看看具体fail的位置, path,
有时候和slack的余量大小有点关系,比如再增加PR里面的setup、hold的margin, 再run下,
不是>0 就可以保证work的,
 楼主| 发表于 2011-9-22 09:11:40 | 显示全部楼层
回复 5# icfbicfb
    谢谢icfb,又看了一下,直接用icc里导出的sdc约束做了一下sta,还是有violation的.
问个其它问题:
  依然是CTS的问题,现在芯片是按两种sscenario来做的,一个是function(主时钟48M,里面有多个生成时钟),另一个scenario是test(主时钟16M,
直接将所有DFF串起来,做DFT),如果只做function的话,skew可做到0.3,但是现在是将两个scenario都将cts_mode设成了true,做出来skew
达4.5,问一下,该如何优化一下这个CTS?
谢谢!
发表于 2011-9-22 23:12:24 | 显示全部楼层
一般 cts scenario只能是一个scenario吧,不能是多个,
如果是多个mode下的cts都要做, 那就不用设cts scenario了,
compile_clock_tree -clock XXX  一个一个做好了,
然后optimize_clock_tree
缺省不设cts scenario的话, 每个scenario的clock都会做的
也可以以func mode为主, test mode很多路径都是用func的clock tree的
发表于 2011-10-31 21:07:30 | 显示全部楼层
学习了阿,谢谢各位大牛的解答,谢谢
发表于 2014-12-4 10:41:33 | 显示全部楼层
回复 7# icfbicfb
   版大。如果是generate clock怎么处理?  是不是吧master clock 长好了就好了
发表于 2014-12-4 14:38:52 | 显示全部楼层
缺省啥都不管,他会自动balance的, 如果不好自己再调整
GMT+8, 2025-12-18 14:37 , Processed in 0.024956 second(s), 5 queries , Gzip On, Redis On.
