查看: 7789|回复: 1
[求助] VHDL attribute 问题
发表于 2011-9-15 17:26:15 | 显示全部楼层 |阅读模式
attribute DLL_FREQUENCY_MODE  : string;
attribute DLL_FREQUENCY_MODE  of LclkDcm : label is "HIGH";
-- attribute DLL_FREQUENCY_MODE  of SysDcm : label is "LOW" ;
attribute CLKOUT_PHASE_SHIFT  : string;
attribute CLKOUT_PHASE_SHIFT  of LclkDcm : label is "VARIABLE";
-- attribute CLKOUT_PHASE_SHIFT  of LclkDcm : label is "FIXED";
-- attribute CLKOUT_PHASE_SHIFT  of LclkDcm : label is "NONE";
attribute PHASE_SHIFT   : string;
attribute PHASE_SHIFT         of LclkDcm : label is "-255";
-- attribute PHASE_SHIFT         of LclkDcm : label is "0";
attribute CLKDV_DIVIDE   : string;
attribute CLKDV_DIVIDE          of LclkDcm : label is "3";
-- attribute CLKDV_DIVIDE          of SysDcm : label is "3" ;
attribute DUTY_CYCLE_CORRECTION : string;
attribute DUTY_CYCLE_CORRECTION of LclkDcm : label is "TRUE";
-- attribute DUTY_CYCLE_CORRECTION of SysDcm : label is "TRUE" ;
attribute DESKEW_ADJUST  : string;
attribute DESKEW_ADJUST         of LclkDcm : label is "SOURCE_SYNCHRONOUS";
-- attribute DESKEW_ADJUST         of SysDcm : label is "2" ;
attribute CLKIN_DIVIDE_BY_2  : string;
attribute CLKIN_DIVIDE_BY_2  of LclkDcm : label is "FALSE";
attribute RLOC_ORIGIN : string;
如果需把VHDL代码转换成verilog代码,VHDL属性 怎么解决呀。请教。
发表于 2011-9-15 21:05:07 | 显示全部楼层
问下前端版面,
GMT+8, 2025-9-30 23:00 , Processed in 1.934890 second(s), 5 queries , Gzip On, Redis On.
