查看: 5140|回复: 12
[求助] 为什么我在modelsim中会出现这种错误?我找了半天都没找出原因,请大家帮忙
发表于 2011-9-9 11:37:41 | 显示全部楼层 |阅读模式
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: F:/yanz/pcie_core/code/pcie_top.v(1998): Module 'PCIE_EP' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_ll_tx.v(647): Module 'LUT6' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(269): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(270): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(271): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(272): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(273): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(274): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(275): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(281): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(345): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(346): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(347): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(349): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(350): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(351): Module 'LUT5' is not defined.
# ** Error: F:/yanz/pcie_core/code/pcie_blk_cf_mgmt.v(352): Module 'LUT5' is not defined.
# Optimization failed
# Error loading design
我的库是加载好的,我找不到原因了。。。请大虾帮我看看,找了好久了,头疼
发表于 2011-9-9 11:47:57 | 显示全部楼层
你确定加载库了吗?LUT就是库里边的东西呢。你看看是不是你编译了,仿真的时候没有加进去。。
发表于 2011-9-9 12:05:45 | 显示全部楼层
要把库编译并加载进去
 楼主| 发表于 2011-9-9 12:40:50 | 显示全部楼层
回复 2# dlb05061131
    编译了啊,而且我找别人帮我看了的LUT5是在里面的呀。。。好奇怪啊。
 楼主| 发表于 2011-9-9 12:41:42 | 显示全部楼层
回复 3# solarwafer
    编译了的。。。。。好奇怪
发表于 2011-9-9 12:42:46 | 显示全部楼层
库肯定没加载正确。
还有一个办法
你可以在生成后仿真网表时,把库的那个选项给勾上。
 楼主| 发表于 2011-9-9 12:49:22 | 显示全部楼层
回复 6# solarwafer
        那您的意思是如何才算加进去呢?我不是太会这个东西,希望能得到您清楚一点的解释,,,,
发表于 2011-9-9 12:54:11 | 显示全部楼层
你可以用另外一个方法,如图,在生存仿真模型前,把有蓝色标记的两个勾给勾上。
 楼主| 发表于 2011-9-9 13:12:28 | 显示全部楼层
回复 8# solarwafer
    您好 ,我的图片传不上去,您有邮箱吗?我发给您看一下。我的好像跟这个选项不太一样12.4
 楼主| 发表于 2011-9-9 13:56:21 | 显示全部楼层
回复 8# solarwafer
    我关联ISE用着就是好的,可是单独启用modelsim就会出现那种文件。。好奇怪
GMT+8, 2025-12-23 21:35 , Processed in 0.024037 second(s), 7 queries , Gzip On, Redis On.
