查看: 7328|回复: 5
[求助] 关于DC的host问题
发表于 2011-9-2 22:25:43 | 显示全部楼层 |阅读模式
我的主机名应当是FRED没错啦,为何启动加载lincense程序时会提示unkonwn host?
以下是输出
[frederickxie@FRED bin]$ hostname
FRED
[frederickxie@FRED bin]$ ./lmgrd -c /home/frederickxie/datum/programData/LICENSE/synopsys/Synopsys.dat
[frederickxie@FRED bin]$ 22:19:30 (lmgrd) -----------------------------------------------
22:19:30 (lmgrd)   Please Note:
22:19:30 (lmgrd)
22:19:30 (lmgrd)   This log is intended for debug purposes only.
22:19:30 (lmgrd)   In order to capture accurate license
22:19:30 (lmgrd)   usage data into an organized repository,
22:19:30 (lmgrd)   please enable report logging. Use Macrovision's
22:19:30 (lmgrd)   software license administration  solution,
22:19:30 (lmgrd)   FLEXnet Manager, to  readily gain visibility
22:19:30 (lmgrd)   into license usage data and to create
22:19:30 (lmgrd)   insightful reports on critical information like
22:19:30 (lmgrd)   license availability and usage. FLEXnet Manager
22:19:30 (lmgrd)   can be fully automated to run these reports on
22:19:30 (lmgrd)   schedule and can be used to track license
22:19:30 (lmgrd)   servers and usage across a heterogeneous
22:19:30 (lmgrd)   network of servers including Windows NT, Linux
22:19:30 (lmgrd)   and UNIX. Contact Macrovision at
22:19:30 (lmgrd)   www.macrovision.com for more details on how to
22:19:30 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
22:19:30 (lmgrd)   for your enterprise.
22:19:30 (lmgrd)
22:19:30 (lmgrd)
22:19:30 (lmgrd)
22:19:30 (lmgrd) Unknown host: FRED
22:19:30 (lmgrd) EXITING DUE TO SIGNAL 33
发表于 2011-10-5 22:43:32 | 显示全部楼层
LZ的问题解决了吗?我也遇到了同样的问题,找了FLEXnet Manager的debug手册,有下面的提示,但目前还不知道如何解决
Unknown host: hostname
The hostname specified on a `SERVER' line in the license file does not exist in the network database.
发表于 2012-1-2 19:57:04 | 显示全部楼层
回复 2# llh1119
   同样的问题啊,,解决了吗???
有方法,能否分享下啊?
发表于 2012-1-2 20:06:21 | 显示全部楼层
是/etc/hosts  里的主机名 没有修改,,貌似。。
hosts:
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1        localhost.localdomain        localhost
发表于 2012-3-13 09:23:12 | 显示全部楼层
4 楼说的对。
修改 /etc/hosts   把local.hostname   改成你实际对机器名
发表于 2012-8-9 17:22:13 | 显示全部楼层
没错,只要把/etc/HOSTNAME中加上主机名,再把/etc/hosts修改,就可以了。
记住重启动net.
GMT+8, 2025-12-14 22:25 , Processed in 0.023507 second(s), 6 queries , Gzip On, Redis On.
