查看: 2438|回复: 4
[求助] 时域离散的开关电容电路如何仿真
发表于 2011-9-1 10:04:13 | 显示全部楼层 |阅读模式
模拟IC设计中,一些开关电路中的电压电流输出量是需要获得平均值的,如何用tran分析仿真开关电路并获得这些需要的平均值。
发表于 2011-9-1 16:38:02 | 显示全部楼层
I use hspice to output these node voltage to text file and calculate the average with matlab or python/perl
 楼主| 发表于 2011-9-4 11:14:01 | 显示全部楼层
回复 2# hugodarwin
    Then how to assure that the output results of these quantities are convergent since the existance of algrithm error? As a matter of fact, the form of output mean value should be like A/B,
未命名11111.jpg where A is the integration of voltage or current to the respect of the time and B is the time region. Ripples at the transition point T1 are difficult for integration.
发表于 2011-9-5 18:23:03 | 显示全部楼层
ding
ding
发表于 2011-9-7 17:04:14 | 显示全部楼层
pss可以仿吧
GMT+8, 2025-12-20 13:39 , Processed in 0.019318 second(s), 7 queries , Gzip On, Redis On.
