查看: 3639|回复: 1
[求助] 求助 IC5141 创建单元verilog描述出现错误
发表于 2011-9-1 09:55:11 | 显示全部楼层 |阅读模式
在Cadence IC5141 中新建一个单元视图 functional ,用vi编辑该单元的verilog描述。保存退出时报出了下面的错误。请问怎么办?
your path points to a ncvlog executable which does not support verilog AMS. Please update your path to point to the correct executable or use vmsNcvlogExecutable variable to specify the executable to use.
发表于 2011-9-11 16:28:53 | 显示全部楼层
没遇到过,试试从schematic创建VERILOG
GMT+8, 2025-12-29 10:04 , Processed in 0.016189 second(s), 5 queries , Gzip On, Redis On.
