查看: 5151|回复: 14
[资料] Advanced Low Power, Multi-Supply Implementation Techniques
发表于 2011-8-24 07:12:14 | 显示全部楼层 |阅读模式
ABSTRACT
Designing low-power ASICs in the nanometer era using 65nm and beyond can be complex. With leakage power becoming more dominant as the process technology shrinks, more methods to reduce idle power need to be used. Multi-supply designs with power-down blocks allow for large reductions in leakage power with the trade-off of design complexity. In this paper we will discuss the methodology and flow that was used to implement a multi-supply design with the latest EDA tools: Design Compiler Topographical and IC Compiler.
galbi_waldo_lowpower_bsnug07.pdf
973.96 KB, 下载次数: 120 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-8-24 08:27:44 | 显示全部楼层
支持发好贴
发表于 2011-8-24 09:22:37 | 显示全部楼层
非常感谢!太好了,我试试!
发表于 2011-8-24 09:29:08 | 显示全部楼层
感谢!
发表于 2011-8-24 10:04:51 | 显示全部楼层
good reference for low power design
发表于 2011-8-24 21:06:00 | 显示全部楼层
谢谢分享!
发表于 2011-8-26 01:20:18 | 显示全部楼层
GOOD DATA, THX...
发表于 2011-8-27 18:21:47 | 显示全部楼层
是篇文章吧。
发表于 2016-5-2 14:22:19 | 显示全部楼层
thanks!
发表于 2016-5-7 13:30:21 | 显示全部楼层
thanks!
GMT+8, 2025-12-28 09:59 , Processed in 0.023136 second(s), 6 queries , Gzip On, Redis On.
