查看: 3200|回复: 4
[原创] debussy的安装过程
发表于 2011-8-13 00:59:00 | 显示全部楼层 |阅读模式
Install Debussy
Then put crs.source, wakt.exe and CRS_NovasDebussy5.1v11.exe in the same folder,
and execute CRS_NovasDebussy5.1v11.exe, for get a license.dat
Next I suggere u to copy the license.dat to  C:\Novas\Debussy\license, and use
C:\Novas\Debussy\bin\lmtools.exe for add a flexlm server
In lmtools, point the C:\Novas\Debussy\bin\lmgrd.exe and the license u created before
with the licgen
Don't forget to add/update the LM_LICENSE_FILE variable to a 28001@yourhostname value
if you are not sure about your hostname value, open the license.dat and check
the first line you shoudl see a HOSTNAME=value where value is your hostname
发表于 2011-8-18 15:25:33 | 显示全部楼层
thank your!!
发表于 2011-9-1 23:59:12 | 显示全部楼层
謝謝分享 很好的資料,受益良多
发表于 2011-9-3 09:37:19 | 显示全部楼层
謝謝分享 很好的資料,受益良多
发表于 2011-9-22 11:42:47 | 显示全部楼层
feichangganxie
GMT+8, 2025-12-12 16:35 , Processed in 0.018202 second(s), 5 queries , Gzip On, Redis On.
