查看: 3601|回复: 6
[招聘] 上海徐汇美资公司 SENIOR IC 测试
发表于 2011-8-3 11:48:27 | 显示全部楼层 |阅读模式
职位是:
Senior/Test Development Engineer
Job Description:
Play a critical role in meeting corporate goals with your experience to develop ATE test hardware + software to support IC design centre.
To develop/convert/migrate hardware + software between test systems to increase test coverage and production throughput.
Enhance the existing test techniques for maximum test quality to minimize customer returns and to reduce test time.
To customize existing test hardware to PCBs for test repeatability, cost effective, maintenance and productive debugging.
To procure essential instruments to continuously upgrade test engineering lab for bench-to-tester correlation.
To develop software tools to reduce test program development cycle time by automating generation of test programs from libraries of proven test methods.
Setup/transfer new products and technology for production off-load at off-shore.
Qualifications:
Knowledge of ATE testing is essential.
Working experience in fast pace semi-conductor manufacturing environment
Process a good sense of responsibility and positive working attitude.
职位是:
Job Description:
Qualifications:
Willing to travel at short notice
BSEE/MSEE in Electronics/Electrical Engineering
Minimum 2 to 5 years of working experience in semiconductor industry.
Experience in Mixed Signals and memory testing is preference.
Good written and oral communications skills.
Knowledgeable in Credence Duo/Teradyne J750, A5 or Catalyst/Agilent AG9300 ATE systems
Able to understand, debug, modify and improve test program.
Able to manage sub-contractors at different locations
Circuit Design (IC) background will be taken as an additional qualification
 楼主| 发表于 2011-8-3 11:48:59 | 显示全部楼层
UP UP
发表于 2011-8-3 17:34:10 | 显示全部楼层
wow!!!!!!
发表于 2011-8-3 17:37:59 | 显示全部楼层
wow!!!!!!
发表于 2011-8-3 17:41:06 | 显示全部楼层
wow!!!!!!
发表于 2011-8-3 17:58:54 | 显示全部楼层
wow!!!!!!!!!!
发表于 2011-8-8 12:24:00 | 显示全部楼层
wow!!!!!!
GMT+8, 2025-12-30 10:12 , Processed in 0.022398 second(s), 6 queries , Gzip On, Redis On.
