查看: 20061|回复: 24
[招聘] (Micron) 美光半导体技术(上海)有限公司 职位热招!!
发表于 2011-7-27 14:07:01 | 显示全部楼层 |阅读模式
美光半导体 上海 研发设计中心 热招 (上海浦东) www.micron.com
美光成立于1978年,总部位于美国爱达荷州博伊西,是全球第二大半导体记忆产品生产商,全球年销售额达50亿美元,是美国纳斯达克证券所上市公司(代码:MU),同时也是美国500强企业之一.美光在芯片设计和生产能力方面在业内处于领先地位,芯片生产技术能力亚30纳米,12英寸,8英寸芯片生产工厂遍布美,亚,欧各洲.美光全球正式雇员超过两万人三千人,子公司遍布全球各地.
在2009全球半导体厂商销售额排行榜上,美光位列全球第14位.截止至目前,美光共享有19980项专利认可,在2009年的全球专利评分排行榜中,美光在总分高达2008.2分,排名第二,仅次于英特尔.2010年5月7日,美光正式完成了对恒忆的收购,该次收购让两大领先的存储器厂商实现强强联合,将推出业内最全面,最具竞争性,同时也最富创新性的产品解决方案.根据数据分析和预测,美光在2010年的销售额将达67亿美元.
美光的动态随机记忆体(DRAM)和闪存(Flash)使用广泛,主要用于计算机系统,电路网路和电讯产品;生活中随处可见的电脑,工作站,网状系统,行动电话,无线装置,数码照相机和游戏系统等,都会使用美光的动态随机存取存储器和Flash闪存产品.在全球,美光客户遍布,主要客户有戴尔(Dell),惠普(HP),苹果(Apple),捷威(Gateway),Sun,IBM,英特尔(Intel),思科(Cisco System),3Com,摩托罗拉(MOTOROLA),诺基亚(Nokia),西门子(Simens)等.
随着Micron Technology全球业务的发展,美光上海研发中心现面对全国IC行业精英招募设计人才!!
有意者请投递简历至: morrisontang@micron.com
Layout Engineer 版图设计工程师
Responsibilities:
•        Develops and prepares multi-dimensional layouts and detailed drawings of the semiconductor devices from schematics and related geometry provided by design engineering. Work may be completed through use of CAD or other computerized equipment. Checks dimensions, writes specifications, and verifies completed drawings, artwork or digitized plots. May check design layouts and detailed drawings. The Engineer will also:
o        Follows broad instructions.
o        Contributes to technical projects with some guidance.
o        Solves problems of moderate complexity.
o        Applies judgment in interpreting results and conducting quantitative analysis.
o        Integrates thorough technical knowledge within discipline.
o        Interacts with more experienced team members and managers to resolve complex problems.
o        Applies knowledge of a single OR multiple sub-function(s).
o        May lead or train others on the team.”
Job Requirements:
•        Bachelor’s Degree in Engineering (Microelectronics, Electronics)
•        At least 3 years relevant experience
•        Custom layout and successful tape-in experience is a must; flash layout experience is a plus
•        Proficiency in layout Electronic Data Automation (EDA) tools such as Virtuoso, Hercules, Calibre in doing layout edit and Lay-out Versus Vchematic (LVS), Design Route Check (DRC), Electric Static Discharge (ESD) and NAC
•        Can work highly independently. Experience in leading a small team is a plus.
•        Good teamwork and communication skills
有意者请投递简历至: morrisontang@micron.com  谢谢!!
 楼主| 发表于 2011-7-27 14:08:53 | 显示全部楼层
CAD Engineer (EDA Design Support)   CAD工程师
In this role, your responsibilities include, but are not limited to:
•        Part of your work will be memory design environment setup and maintenance, which include—
o         Interfacing EDA vendors for tools' evaluation, maintenance, installment
o        Setting up and maintaining product design environment.
o        Providing solutions to design engineer when they find issues on design environment or tools.
•        Another important part of the job is flow development and support to FE /BE team, which include—
o        Providing Perl, C, Skill, Tcl scripts support for design team.
o        Developing new methodology and flows to improve productivity and control quality, the main flows include:
FE: Synthesis, Simulation, STA, and Validation etc.
BE: Place and Routing, Customer layout, Physical verification, Power analysis etc.
Major of computer science, micro-electronic or related. Master degree or bachelor degree with 2+ year related experience or above.
•        Strong program capability of Skill, Perl, Tcl/Tk, C, etc in unix/linux and a strong desire to automate flow
•        Knowledge of design EDA tools such as Cadence Schematic entry, Eldo/Hspice, Verilog, ADMS, Modelsim, Conformal, PT, DC experience
•         Familiar with IC design/layout flow
•        Good written and spoken English
•        Good communication skills and be able to work both independently and in a team
•        Real ASIC project experience as a FE or BE designer is a plus     
 楼主| 发表于 2011-7-27 14:10:40 | 显示全部楼层
NAND Verification Engineer  NAND设计验证工程师
Description:
As an IC Verification Engineer or Senior Verification Engineer in Flash Group at Micron Technology, Inc., you will be part of a team that develops and verifies many NAND products with global teams in USA, Japan, Italy and local. Your primary areas of responsibilities will include generation of test cases used in functional verification, development and maintenance of testbench, writing assertions, developing or testing new verification methodologies, and running regressions. You will work closely with global design and verification engineers in developing the testplan and debugging test failures.
Qualifications:
- Proven track record for successful verification of IC products in the past;
- Strong background in Verilog and verification methodology; knowledge of SystemVerilog or other HVL a plus;
- Knowledge and experience in writing assertions, OVM, etc;
- Knowledge and experience with Perl and Unix/Linux scripting strongly desired;
- A high-level of self-motivation and a proactive approach to solving problems;
- Good English communications skills.
Education:
BS or MS in Electrical or Computer Engineering with 3+ years of verification engineering experience is required.
www.micron.com
 楼主| 发表于 2011-7-27 14:13:01 | 显示全部楼层
Component Design Engineer - Analog 模拟电路设计工程师
Job Description:
Summary: Detailed design of analog/mixed-signal circuits, including design capture, layout, test, evaluation and debugging of circuit and design support for mass production.
Has the flash memory design experience is preferred.
Essential Functions:
•        Architects, designs and verifies circuits, logic, systems, algorithms, etc. to meet product requirements.
•        Determines design approaches and parameters. Responsible for custom layout, including overseeing the work of layout designers. Conducts evaluation of design results by laboratory measurements of ICs.
•        Reports on design results through design reviews, in accordance with company quality requirements and resolves action items generated as a result of these reviews. Attends design reviews to provide input and guidance to other designers.
Education and/or Experience: Major of micro-electronic is preferred. Bachelor's degree with 3+ year experience or Master degree required. An advanced degree may reduce the minimum experience required.
Knowledge, Skills and Abilities:
•        Understanding of engineering fundamentals
•        Knowledge of complex AC/DC analysis (poles, zeros, compensation)
•        Signal analysis knowledge (convolution, transforms)
•        Parasitic analysis knowledge (capacitance, resistance, power grid, package)
•        MOS Device modeling skills (noise, excess thermal noise, DIBL)
•        Knowledge of CMOS fabrication processes.
•        Knowledge of MOS transistors and analog/digital circuit design
•        Knowledge of digital design and design flows for optimal design results (area, timing, power)
•        Knowledge of design EDA tools such as Cadence Schematic entry, Eldo/Hspice experience
www.micron.com
 楼主| 发表于 2011-7-27 14:14:42 | 显示全部楼层
Component Design Engineer - Logic   逻辑电路设计工程师
Job Description:
Summary: Detailed design of logic/mixed-signal circuits, including design capture, layout, test, evaluation and debugging of circuit and design support for mass production.
•        Be responsible for mixed-signal chip's logic design and verification, including block level specification, micro architecture design, RTL coding and verification, synthesis and power and static timing analysis.
•        Own the design of all digital blocks in flash memory. Applicant should have basic technical skills on how to design digital block, have working knowledge of general integrated circuit design flow and EDA tools with some work experience.
Education and/or Experience: Major of micro-electronics is preferred. Bachelor's degree with 3+ year experience or Master degree required. An advanced degree may reduce the minimum experience required.
•        Strong VHDL coding and RTL design skills
•        Familiar with digital simulator, Synopsys synthesize and timing analysis tools
•        Familiar with IC design flows
•        Familiar with Perl language or C++, tcl script is preferred.
•        Dedicated, hard working and good team player
•        Posses good interpersonal as well as good communication skills     
www.micron.com
 楼主| 发表于 2011-7-27 14:15:50 | 显示全部楼层
Application Engineer 应用工程师
Job description:
-        Provides technical expertise and value to customers. Assignments include interpretations of designs, applications, and service information. Typically interacts with sales team, manufacturing, and marketing personnel. Gathers information concerning the capabilities of company products.
-        Typically is required to make or assist in technical presentations, demonstrations, and customer training. May work through all phases of customer interaction including customer analysis, design implementation and product manufacturing. Represents customers' interests at technical meetings within the company.
-        Exploring Micron’s memory opportunities based on different segments, promoting Micron’s total memory solutions and developing the first prototype based on customers’ needs.
-        Educating, influencing and driving ESG memory solutions, strategies, and value proposition with ESG development team and Marketing personal; stimulate customer awareness through technical supporting, trainings and technical seminars.
Requirement:
-        EE bachelor or master degree.
-        Excellent communication & collaboration skills.
-        Excellent structured problem solving skills.
-        Willingness of frequent travelling.
-        Embedded system working experience is preferred.
www.micron.com
 楼主| 发表于 2011-7-27 14:17:11 | 显示全部楼层
Validation Engineer 测试验证工程师
Job Description:
•        At pre-silicon phase, you need to involve in silicon simulation activities and debug activities to further understand the functions which will be used in post silicon validation.
•        At pre-silicon phase, you need to develop/define/build the test method, test plan, test coverage with design engineer and work with test engineer for test program development.
•        At post-silicon phase, you need to finish chip level function/performance data collection with multiple platforms.
•        At post-silicon phase, you need to define product validation schedule to meet the overall project schedule and achieve business win.
•        At post-silicon phase, you need to analyze the data, debug and understand every single abnormal and test failure.
•        Give customer quick response for application issue. Be able to identify the customer reported failure and understand the root cause, provide with satisfied solutions.
Requirement:
•        Electrical/electronic engineering, computer science background with BS or MS degree.
•        Knowledge of C++ coding. Knowledge of script language (Perl, Python etc.), skill of O-scope and logic analyzer is a plus.
•        Knowledge of flash memory is a plus.
•        A high-level of self-motivation and a proactive approach to solve problems.
•        Good communications skills, be able to work under pressure.
•        Willing to take short domestic and international travel.
www.micron.com
 楼主| 发表于 2011-7-27 20:58:55 | 显示全部楼层
up up up ...
 楼主| 发表于 2011-7-27 21:00:55 | 显示全部楼层
另有
Technical Marketing Engineer
Senior FAE - Shenzhen
QRA Engineer
等等
有兴趣者请发简历至: morrisontang@micron.com
发表于 2011-7-28 00:06:02 | 显示全部楼层
micron
GMT+8, 2025-12-18 16:49 , Processed in 0.018646 second(s), 4 queries , Gzip On, Redis On.
