楼主: lxing_1988
[资料] cadence ic6141 大附件上传~~上传完毕(有crack!)!!!
发表于 2017-5-18 08:35:32 | 显示全部楼层
回复 1# lxing_1988
Thank you splitting the file to smaller chucks
发表于 2017-5-18 08:38:01 | 显示全部楼层
回复 1# lxing_1988
is there an easier way to download so many files, 195?
发表于 2017-5-18 08:38:45 | 显示全部楼层
回复 558# xiaoyisimonguo
   I used up all my credits
发表于 2017-5-18 14:18:17 | 显示全部楼层
回复 557# xiaoyisimonguo
   still took too long to download
发表于 2017-5-19 04:12:15 | 显示全部楼层
回复 1# lxing_1988
good downloads for IC6
发表于 2017-5-19 07:18:07 | 显示全部楼层
没有网盘么?
发表于 2017-5-19 08:35:26 | 显示全部楼层
回复 1# lxing_1988
   downloaded, but license not done, in your readme.txt, I should simply
./patch_cadence
but what I got
./sfk: /lib/libstdc++.so.5: version `GLIBCPP_3.2' not found (required by ./sfk)
./sfk: /lib/libstdc++.so.5: version `CXXABI_1.2' not found (required by ./sfk)
please help
 楼主| 发表于 2017-6-12 17:18:56 | 显示全部楼层
回复 563# xiaoyisimonguo
    you should install libstdc++ in your operation system
发表于 2017-6-13 08:09:36 | 显示全部楼层
回复 1# lxing_1988
Please help
  successfully installed ic614 on a centOS7 machine
but when I tried virtuoso
I got these:
virtuoso &
[2] 3545
[1]    Exit 1                        viruoso
codelion-ic6141 61 > ERROR: Could not find Cadence installation root for
/home/tools/cadence/ic06.14/tools/bin/cdsGetOABinPath
Make sure that cdsGetOABinPath is part of the Cadence installation.
virtuoso:   ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsGetOABinPath.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
发表于 2017-6-13 12:35:24 | 显示全部楼层
thanks
GMT+8, 2025-12-24 22:15 , Processed in 0.017524 second(s), 3 queries , Gzip On, Redis On.
