查看: 8291|回复: 24
[原创] 2011年TCASII low-power cap-free的LDOs design
发表于 2011-7-14 10:39:19 | 显示全部楼层 |阅读模式
2011年TCASII low-power cap-free的LDOs designDynamic Bias-Current Boosting Technique for Ultralow-Power Low-Dropout Regulator in Biomedical Applications
Abstract:A dynamic bias-current boosting technique that concurrently enables ultralow-power operation and fast-transient behavior is presented in this brief. It is applied to an ultralow-power output-capacitor-free  low-dropout  regulator  (LDO)  to  demonstrate  the  bandwidth  extension  provided  during  the  transient periods.  The  proposed  LDO  is  capable  of  providing  50  mA  of output current with a minimum dropout voltage of 0.1 V. The ultralow-power  LDO  is implemented  in  a commercial  0.13-μm CMOS process, with power consumption of 1.20 μW only. Experimental  results  verify  that  both  the  load-  and  line-transient responses of the proposed LDO are significantly improved, and the settling times during load and line transients are shortened by as much as 33 and 3 times, respectively.
 楼主| 发表于 2011-7-14 10:45:26 | 显示全部楼层
Update attached file. Sorry!
TCASII low-power cap-free LDO.pdf
460.96 KB, 下载次数: 276 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-7-15 00:36:29 | 显示全部楼层
i like it
发表于 2011-7-15 00:44:25 | 显示全部楼层
感謝您的分享!!
謝謝!!
发表于 2011-7-15 10:09:11 | 显示全部楼层
duoxie duoxie
发表于 2011-7-15 22:21:26 | 显示全部楼层
kan yi kan le
发表于 2011-7-16 08:59:39 | 显示全部楼层
good stuff
发表于 2011-7-16 09:56:26 | 显示全部楼层
dfdfdfdf
发表于 2011-7-27 13:31:22 | 显示全部楼层
看看~~~
发表于 2011-7-29 09:28:51 | 显示全部楼层
thanks~
GMT+8, 2025-11-22 08:29 , Processed in 0.031730 second(s), 7 queries , Gzip On, Redis On.
