查看: 18053|回复: 14
[求助] sdf文件是个什么意思?
发表于 2011-6-27 13:32:25 | 显示全部楼层 |阅读模式
看xilinx ise中间Isim uer guide中间有这么一段话:“It is also possible to instruct the simulator to use the correct timing delays from the SDF file.”这里面的SDF文件是什么东西?
发表于 2011-6-27 15:14:46 | 显示全部楼层
延时信息文件
发表于 2011-6-27 16:46:35 | 显示全部楼层
sdf- standrad dealy format,标准延时格式文件,delay分为cell delay 和wire delay,cell delay是指元器件内部的delay,wire delay是器件互连Pin-to-pin的delay。真正的delay,就是这两者的累加。
发表于 2011-6-27 19:12:29 | 显示全部楼层
网表仿真所使用的文件吧
发表于 2011-6-27 22:55:44 | 显示全部楼层
standard delay file
发表于 2011-6-28 12:25:31 | 显示全部楼层
PR之后提取出来的,用于后仿的描述各种delay的文件
发表于 2011-6-28 14:21:13 | 显示全部楼层
The Standard Delay Format (SDF) file stores the timing data generated by
EDA tools for use at any stage in the design process. The data in the SDF
file is represented in a tool-independent way and can include
請看這裡http://www.vhdl.org/sdf/sdf_3.0.pdf
 楼主| 发表于 2011-6-28 15:00:46 | 显示全部楼层
感谢了!
发表于 2011-7-18 09:01:28 | 显示全部楼层
延时信息文件
发表于 2011-7-21 10:29:23 | 显示全部楼层
The SDF file extension can be used as a schedule data file, a source definition file, a standard data format, a standard delay format, and a system data format.
GMT+8, 2025-9-19 06:51 , Processed in 0.019569 second(s), 5 queries , Gzip On, Redis On.
