楼主: indianhill
[招聘更新]美资Agere(朗讯)上海高薪招聘存储和通讯方向IC设计师
发表于 2007-1-2 12:50:18 | 显示全部楼层
不错,让我想起了一年前,面对各种工作机会的冲动
发表于 2007-1-10 11:59:40 | 显示全部楼层
我看了不想看
发表于 2007-1-11 11:17:05 | 显示全部楼层
就怕三五年经验了,去了还是干点边角料活
 楼主| 发表于 2007-1-11 12:12:58 | 显示全部楼层
1月11日,尚有33个技术职位虚位以待。
Analog IC Designer for Hard Disk Drive Read Channel   4
ASIC Design Engineer   2
ASIC Verification Engineer (Junior-Level, 1-3 Years Exp.) 4
Digital IC Design Engineer 4
Analog IC Design Engineer (Mid-Level, 4-6 Years Exp.)  5
Sinior Digital IC Design Engineer  6
Pysical Design Engineer    4
具体的职位信息,请看:
http://www.agere.com/careers/careersearch.html
有意者请发送中、英文简历至 : agerechina@gmail.com
发表于 2007-1-15 12:32:46 | 显示全部楼层
有兴趣哦,工作快两年
 楼主| 发表于 2007-1-19 17:50:07 | 显示全部楼层
1月19日,尚有29个技术职位虚位以待。
具体的职位信息请参看:
选择 “China", search.
有意者请发送中、英文简历至agerechina@gmail.com
如有任何疑问或问题,也可发送agerechina@gmail.com
谢谢。
发表于 2007-2-28 21:13:07 | 显示全部楼层
回复 #26 indianhill 的帖子
Analog 现在还空缺么?
 楼主| 发表于 2007-2-28 22:12:23 | 显示全部楼层
Analog IC Design Engineer (Mid-Level, 2-6 Years Exp.) – TEN0000002H--   通讯 有一个职位空缺;
Analog IC Design Engineer (Mid-Level, 4-6 Years Exp.) – STO00000 -------  存储 有两个职位空缺。
Job Responsibilities
Duties will include working within a Product Development Team to create (design, layout, and evaluate) new circuit architectures, and to modify existing circuit architectures, verify functionality of designs, prepare and present Design Reviews to internal groups and external customers, write technical reports, attend technical conferences in the areas of data storage and advanced IC design. Specific responsibilities include:
-          Communicate effectively within a global business environment (must be proficient in both spoken and written English).
-          Perform transistor level, analog and mixed signal integrated circuit design of various cells and blocks within custom chips for the hard disk drive industry. Examples of some blocks are: voltage regulators, bandgap circuits, data converters (DAC, ADS), low noise amplifiers, line drivers, multipliers, temperature sensing circuits, filters, operational amplifiers, variable gain amplifiers,  control logic, serial port controller.
-          Support the integration of all cells and blocks into a completed integrated circuit
-          Work directly with customers to determine the system requirements, write specifications, and guide them on the use of our preamplifier products.
-          Conduct detailed design reviews of cell and block level circuits.
-          Perform design validation thru simulation with Cadence software.
-          Use highspeed electronic characterization equipment to evaluate and debug the functionality of the silicon
-          Perform transistor level and block level layout (physical design).
-          Provide technical support and guidance to a cross functional team of engineers thru all phases of product development which includes: test, yield, characterization, reliability analysis, qualification, and release to manufacturing.
-          Adhering to schedule, die size, and power commitments.
Qualifications
Functional/Industry Knowledge
Required:
- Minimum of 4-6 years Analog IC Design experience in a product development environment
- Proven Analog IC Design skills
- Proven experimental skills and lab/bench expertise
- Strong written and verbal communication skills
Desired:
- Past experience in a lead position giving guidance to other engineers
Education/Certifications
Required Degree: BS
Preferred Degree: MS
Preferred Major: Electrical Engineering or related discipline
[ 本帖最后由 indianhill 于 2007-2-28 22:16 编辑 ]
发表于 2008-1-19 21:35:36 | 显示全部楼层
为啥用gmail而不用公司的邮箱?
可疑!
发表于 2008-1-20 21:11:29 | 显示全部楼层
好老的帖子被翻出来,置顶不可能啦
呵呵,兄弟,正常企业的招聘也都来的话,那都置顶的话那会太多啦:)
所以,不是偶不给你置顶,是还没到置顶的必要或者水平,请理解哦,兄弟:)
[ 本帖最后由 blackhyw 于 2008-1-20 21:48 编辑 ]
GMT+8, 2025-12-29 12:40 , Processed in 0.024354 second(s), 3 queries , Gzip On, Redis On.
