楼主: fsgbeyond
[求助] ic610启动spectre错误
发表于 2017-7-21 17:49:11 | 显示全部楼层
回复 10# fsgbeyond
大神,能不能帮我看看仿真时的错误,真的万分感谢
ERROR (ADE-3023): Unable to locate spectre executable in the specified path. Ensure that
        the executable is present in the path or to set the correct path, use
        the setShellEnvVar() in Command Interpreter Window (CIW).
Simulation unsuccessful during parametric sweep
export DD_DONT_DO_OS_LOCKS=SET
export CDS_LIC_FILE=$CDS_ROOT/IC616/share/license/license.dat
export LM_LICENSE_FILE=$CDS_ROOT/IC616/share/license/license.dat
export SPECTRE_DEFAULTS=-E
export CDS_Netlisting_Mode=Analog
export OA_HOME=$CDS_ROOT/IC616/oa_v22.43.040
export PATH=$CDS_ROOT/IC616/tools/binPATH
export PATH=$CDS_ROOT/IC616/tools/dfII/binPATH
export PATH=$CDS_ROOT/IC616/tools/spectre/binPATH
export PATH=$CDS_ROOT/IC616/share/bin:$PATH
export PATH=$CDS_ROOT/IC616/share/cdsdoc/bin:$PATH
export PATH=$CDS_ROOT/MMSIM141/tools.lnx86/bin:$PATH
export CDS_TEST_LIBPATH=/usr/lib:/lib
发表于 2017-7-21 17:56:46 | 显示全部楼层
求大神帮我看看我仿真时产生的错误,真的跪谢,
我是个初学者,拜托大神们带带我,万分感谢
The netlist is up to date.
        Time taken to compare the design with netlist:   0.0s
我的环境:
 楼主| 发表于 2017-9-20 19:53:55 | 显示全部楼层
回复 12# leojoyfun
    不好意思,毕业后就没再搞模拟了,我也不知道怎么解决。。。
GMT+8, 2025-12-19 12:26 , Processed in 0.013016 second(s), 3 queries , Gzip On, Redis On.
