查看: 8754|回复: 17
[资料] 10 Bits 100MS/s DAC for IEEE 802.11a
发表于 2011-6-23 17:24:30 | 显示全部楼层 |阅读模式
10 Bits 100MS/s Digital to Analog Converter for IEEE 802.11a
for IEEE 802.11a
student:Liang Chuchen Advisors:Dr. Lan-Rong Dung
Degree Program of Electrical Engineering Computer Science
National Chiao Tung University
ABSTRACT
This thesis describes a 10-bit 100MS/s digital to analog converter (DAC) for
IEEE 802.11a. For high-speed application, The current-source mode has been
popular in high speed digital to analog converter applications. However, to
obtain accurate current-source is not easy due to process variation. Although
several calibration circuits are proposed to improve the accuracy, the cost and
circuit complexity are usually very large. In this thesis, based on traditional
threshold-voltage compensation method, we use a new current source biasing
technique to reduce the current error caused by inevitable threshold-voltage
variation, transistor (w/l) size variation, power-source variation and temperature
change. Finally we apply this technique to 10-bit weighted-current-source digital
to analog converter. SPICE simulations show that for 0.35-μm TSMC Mixed
Signal 2P4M process with a 3.3 V power supply; the digital to analog converter
variation is reduced significantly.
錄
中文摘要.................................................................................................................................................................I
ENGLISH ABSTRACT ...................................................................................................................................... II
志谢..................................................................................................................................................................... III
錄......................................................................................................................................................................IV
表目錄......................................................................................................................................................................... VII
图目錄...............................................................................................................................................................VIII
第一章 論..................................................................................................................................................... 1
1.1 简介..................................................................................................................................................... 1
1.2 研究动机............................................................................................................................................. 2
1.3 論文组织............................................................................................................................................. 3
第二章
數
/類比转换器原理....................................................................................................................... 4
2.1 數/類比转换器(DAC) ...................................................................................................................... 4
2.2 理數/類比转换器(IDEAL DAC) .................................................................................................... 4
2.3 數/類比转换器(DAC)规格參數...................................................................................................... 5
2.3.1
解析度(Resolution) ..................................................................................................................... 5
2.3.2
偏移误差(Offset error) ............................................................................................................. 5
2.3.3
益误差(Gain error) ................................................................................................................. 6
2.3.4
精
度(Accuracy) ......................................................................................................................... 7
2.3.5
累
积非线性误差(Integral nonlinearity error INL)............................................................ 7
2.3.6
差动非线性误差(differential nonlinearity error DNL).................................................... 8
2.3.7
稳定时间(settling time) ........................................................................................................... 8
2.3.8
转换率(Conversion rate ) ......................................................................................................... 8
2.3.9
单调增加特性( Monotonicity ) ................................................................................................. 8
2.4 數類比转换器基本架构............................................................................................................. 9
2.4.1
电阻串列數/類比转换器(Resistor-String DAC).............................................................. 9
2.4.2
兩
级电阻式數/類比转换器(2-STAGE RESISTOR-STRING DAC) ................................................... 10
2.4.3
权重电阻式數/類比转换器(BINARY-WEIGHTED RESISTOR DAC) .................................................. 10
2.4.4
R-2R
电阻梯式數/類比转换器(R-2R ladders DAC)............................................................. 11
2.4.5
电容电荷重新分布式數/類比转换器(CHARGE-REDISTRIBUTION SWITCHED-CAPACITOR DAC) ........ 12
2.4.6
二进制代码权重电流切换式數/類比转换器.............................................................................. 14
2.4.7
度计码电流切换式數/類比转换器(CURRENT MODE THERMOMETER CODE DAC) .......................... 16
2.4.8
度计码与二进制权重码共享的区段式电流數/類比转换器.......................................... 18
2.4.9
超取样频率數/類比转换器(OVERSAMPLING DAC) ...................................................................... 21
第三章
切
换电流源式數/類比转换器电路设计...................................................................................... 27
3.1 12 BIT 數/類比转换器规格........................................................................................................... 27
3.2 12-BIT 數/類比转换器电路.......................................................................................................... 28
3.2.1 12-bit 數/類比转换器电路架构............................................................................................ 28
3.2.2 流源电路—抗制程变因的偏压电流源技术............................................................................ 29
3.2.3 差动式切换开关驱动控制电路................................................................................................... 30
3.2.4 减少开关切换所产生突波对DAC 输出影响................................................................................ 32
3.2.5 流源电路—增加电流源输出阻抗技术................................................................................... 35
3.2.6 流gradient error 问题解决技术.................................................................................... 35
3.2.7 二进码转温度计码编码电路....................................................................................................... 38
3.2.8 完整电路...................................................................................................................................... 41
3.3 路模拟结果............................................................................................................................... 42
第四章 芯片布局........................................................................................................................................... 47
4.1 流源设计和布局.................................................................................................................................. 47
4.1.1 流源设计..................................................................................................................................... 47
4.1.2 度计码电流源布局................................................................................................................... 50
5.1 度计码编码电路设计和布局........................................................................................................ 51
5.1.1 二进制代码转温度计码编码电路................................................................................................... 52
5.2 Post simulation 模拟结果
....................................................................................................... 59
第五章 测试设定和量测结果........................................................................................................................ 62
5.1 测试环境设定................................................................................................................................... 62
5.2 量测结果........................................................................................................................................... 65
六章结論与未來工作展望........................................................................................................................ 69
10 Bits 100MSs Digital to Analog.pdf
1.82 MB, 下载次数: 294 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-6-24 09:22:44 | 显示全部楼层
有简介有目录,不错!
发表于 2011-6-24 10:01:47 | 显示全部楼层
有简介有目录
有简介有目录
发表于 2011-6-24 11:59:41 | 显示全部楼层
thx very much
发表于 2011-6-24 14:17:57 | 显示全部楼层
很好,下来看看
发表于 2011-6-24 20:33:38 | 显示全部楼层
no measurement results
发表于 2011-6-24 21:46:41 | 显示全部楼层
Thank!!!
发表于 2011-6-24 22:29:25 | 显示全部楼层
谢谢分享啊
发表于 2012-5-12 14:49:55 | 显示全部楼层
谢谢分享
发表于 2015-1-14 22:10:32 | 显示全部楼层
下载 学习
GMT+8, 2025-12-25 21:27 , Processed in 0.034075 second(s), 6 queries , Gzip On, Redis On.
