查看: 11113|回复: 14
[求助] modelsim-altera 6.6d 破解后不能使用(急急急!)
发表于 2011-6-22 21:43:59 | 显示全部楼层 |阅读模式
操作系统是xp,破解时关掉了杀软、360。
modelsim-altera 6.6d的破解顺序是:
1、运行make.bat,生成了一个license.dat文件;(直接运行MentorKG.exe总是生成不了license。)
2、添加了系统环境变量MGLS_LICENSE_FILE;(生成LM_LICENSE_FILE也试过)
3、把MGLS.DLL和mgc.pkginfo文件拷贝到了win32aloem目录下,选择了覆盖。
到这里,破解完,运行程序没有报错。
在transcript中指定工程目录时报错,错误如下:
# can't read "map(桌)": no such element in array
并且一旦关闭程序就报错,且只能用任务管理器来强关。错误如下:
save messages后得到的两个文件中内容为:
文件tcl_stacktrace.txt中的内容 Wed Jun 22 20:48:13 ?????? 2011
Trace back: can't read "map(?)": no such element in array
    while executing
"quit"
    (command for "WM_DELETE_WINDOW" window manager protocol)
  <2: ::tkerror {can't read "map(?)": no such element in array}
  <1: ::bgerror {can't read "map(?)": no such element in array}
Wed Jun 22 20:59:58 ?????? 2011
    while executing
"quit"
Wed Jun 22 21:36:43 ?????? 2011
    while executing
"quit"
文件transcript中的内容是:
# Reading C:/altera/11.0/modelsim_ae/tcl/vsim/pref.tcl
# error: Load_NoDesignLayout can't read "map(L)": no such element in array
# can't read "map(L)": no such element in array
#     while executing
# "subst -nocommands $string"
#     (procedure "encode" line 11)
#     invoked from within
# "encode $ukey"
#     (procedure "getMTIProperty" line 11)
# "getMTIProperty $geomKey main_size "" "
#     (procedure "LoadLayout" line 35)
# "LoadLayout NoDesign quitsim"
#     ("eval" body line 1)
# "eval "LoadLayout $new_layout_name quitsim""
#     (procedure "Layout:oad_NoDesignLayout" line 3)
# "Layout:oad_NoDesignLayout"
cd d:/Workspace/Matlab/s2_hdlcoder_work
#  Trace back: can't read "map(L)": no such element in array
#     while executing
# "quit"
#     (command for "WM_DELETE_WINDOW" window manager protocol)
#    <2: ::tkerror {can't read "map(L)": no such element in array}
#    <1: ::bgerror {can't read "map(L)": no such element in array}
这是怎么回事?该怎么解决?请各位大大帮忙啊!
发表于 2011-6-22 23:14:48 | 显示全部楼层
帮顶,看你刚注册也知道你很急,你用免费的不行么
发表于 2011-6-23 01:04:19 | 显示全部楼层
你的license所在的目录名不能包含中文字符吧   换个地方放license   比如直接放在C盘下
 楼主| 发表于 2011-6-23 08:37:29 | 显示全部楼层
回复 3# shawnelee88
    您说的这些都注意了。之前用的版本是6.5b的。后来把软件都重装了一遍,还是会出现这问题。问了别人,破解后正常,不知道我有什么地方没注意到?
发表于 2011-6-27 16:36:23 | 显示全部楼层
我也是这样,不知道怎么办
发表于 2011-6-27 19:15:10 | 显示全部楼层
发表于 2011-7-1 11:22:01 | 显示全部楼层
我破解的时候发现一个问题,就是如果还装了其它有lmtools的软件的话,比如说STK,可能会有冲突
发表于 2011-7-6 11:03:35 | 显示全部楼层
问题解决没,我的也是这样,就是路径改不了
发表于 2011-8-27 15:16:16 | 显示全部楼层
這個問題我也碰過.
是中文字造成的.
修改一個初始檔即可.
移除中文"桌面"
发表于 2011-9-11 23:09:37 | 显示全部楼层
楼主,请问生成的license.dat放在哪个目录下?能再详细说说破解步骤吗?
GMT+8, 2025-9-18 03:16 , Processed in 0.019796 second(s), 6 queries , Gzip On, Redis On.
