查看: 6883|回复: 9
[招聘] 著名美资上市高科技公司诚聘RFIC Layout Engineer@上海
发表于 2011-6-22 14:57:29 | 显示全部楼层 |阅读模式
Job Description
You will work closely with a world-class team of IC designers to perform physical design of highly-integrated, high-performance ICs with RF, analog, mixed-signal, and digital signal processing systems integrated on a single chip.  Responsibilities include physical design of demanding mixed-signal and RF layout blocks, chip-level floorplanning, place and route of digital blocks, top-level chip assembly, full-chip verification, chip tapeout, and mask data verification.  This position will require strong communication and problem-solving skills.  Versatility, initiative and the ability to adapt to a dynamic startup environment are essential.
Requirement:
  • BS Degree in EE (with relevant specialization) or higher, with 5+ years of industrial working experience.
  • Experience in analog and digital IC physical design with exposure to top-level assembly and chip tapeout procedures
  • Solid understanding of physical, electrical rules and DFM rules for fine-geometry CMOS processes
  • Direct experience in RF layout and knowledge of semiconductor devices and fabrication principles
  • Proficiency in block level floorplanning, understanding of device matching issues such as WPE and STI
  • Ability to estimate and minimize parasitics prior to detailed layout extraction
  • Comprehension of isolation issues and ability to create effective shielding / isolation structures
  • Experience with industry-standard layout and verification tools (Cadence: Viruoso, Assura, Encounter; Mentor: Calibre) and proficiency in a Unix workstation environment
  • Experience with PCB layout tools, lab test and measurement equipment, VBA programming or LabView programming beneficial.
 楼主| 发表于 2011-6-22 15:20:37 | 显示全部楼层
有意向者请联系Veronica,发送简历至veronica@genhr.com
或拨打65081009转131
或15921267159
谢谢!
发表于 2011-6-22 20:04:51 | 显示全部楼层
这样的职位,至少要25k,否则不要去
发表于 2011-6-22 21:53:47 | 显示全部楼层
layout工程师可能拿不到这么高的工资,华为工作5年,一年的年薪全加起来才不过20w
发表于 2011-6-23 08:27:58 | 显示全部楼层
25K?????????
发表于 2011-6-23 09:42:50 | 显示全部楼层
华为??laji,自认为这家公司还不错
发表于 2011-6-23 15:37:38 | 显示全部楼层
你那里有北京的模拟IC设计职位没?工作5年了,想换下。
 楼主| 发表于 2011-6-24 15:38:22 | 显示全部楼层
hardmany 发表于 2011-6-23 15:37
   目前没有哦~不好意思
要不要来上海试一下?哈哈
 楼主| 发表于 2011-6-29 10:36:53 | 显示全部楼层
up up again
 楼主| 发表于 2011-7-7 09:22:18 | 显示全部楼层
up up third time
GMT+8, 2025-12-15 01:17 , Processed in 0.022043 second(s), 6 queries , Gzip On, Redis On.
