查看: 5537|回复: 5
用MATLAB实现频域平滑滤波以及图像去噪代码 求解
发表于 2011-6-21 10:31:03 | 显示全部楼层 |阅读模式
MATLAB实现频域平滑滤波以及图像去噪代码运行出错(急等)
下面的代码是我在网上搜的,运行以后提示出错,请各位帮忙看看。
% the SF filter is unselective to orientation (doughnut-shaped in the SF
% domain).
[FileName,PathName,FilterIndex] = uigetfile ;
filename = fullfile(PathName, FileName) ;
[X map] = imread(filename, fmt); % read image
L = double(X); % transform to double
%%%%%%%%%%%%% need to add (-1)x+y to L
% calculate the number of points for FFT (power of 2)
fftsize = 2 .^ ceil(log2(size(L)));
% 2d fft
Y = fft2(X, fftsize(1), fftsize (2));
Y = fftshift(Y);
% obtain frequency (cycles/pixel)
f0 = floor([m n] / 2) + 1;
fy = ((m: -1: 1) - f0(1) + 1) / m;
fx = ((1: n) - f0(2)) / n;
[mfx mfy] = meshgrid(fx, fy);
% calculate radius
SF = sqrt(mfx .^ 2 + mfy .^ 2);
% SF-bandpass and orientation-unselective filter
filt = SF > k0;
A_filtered = filt .* A; % SF filtering
L_filtered = real(ifft2(ifftshift(A_filtered))); % IFFT
L_filtered = L_filtered(1: size(L, 1), 1: size(L, 2));
%%%%%%%%%%need to add (-1)x + y to L_filtered
% show
figure(1);
clf reset;
colormap gray;
% plot image
subplot(2, 2, 1);
imagesc(L);
colorbar;
axis square;
set(gca, 'TickDir', 'out');
title('original image');
xlabel('x');
ylabel('y');
imwrite(L, fullfile(FilePath, 'original image.bmp'), 'bmp') ;
% plot amplitude
A = abs(A);
A = log10(A);
% spectral amplitude
subplot(2, 2, 2);
imagesc(fx, fy, A);
axis xy;
axis square;
title('amplitude spectrum');
xlabel('fx (cyc/pix)');
ylabel('fy (cyc/pix)');
imwrite(A, fullfile(FilePath, 'amplitude spectrum.bmp'), 'bmp') ;
% filter in the SF domain
subplot(2, 2, 3);
imagesc(fx, fy, filt);
axis xy;
axis square;
title('filter in the SF domain');
imwrite(filt, fullfile(FilePath, 'filter in SF.bmp'), 'bmp') ;
% filtered image
subplot(2, 2, 4);
imagesc(L_filtered);
colorbar;
axis square;
title('filtered image');
xlabel('x');
ylabel('y');
imwrite(filtered, fullfile(FilePath, 'filtered image.bmp'), 'bmp');
%%%%%%%%%%%%%%%%%median filter%%%%%%%%%%%%%%%%
[LNoise map] = imread(filename, fmt); % read image
L = medfilt2(LNoise, [3 3]); % remove the noise with 3*3 block
figure ;
imshow(LNoise) ;
title('image before fitlering') ;
figure
imshow(L)
title('filtered image') ;
imwrite(FilePath, 'filtered image.bmp', bmp)
提示错误:??? Undefined function or variable 'fmt'.
??? Undefined function or variable "m".
发表于 2011-6-22 19:40:19 | 显示全部楼层
The text string FMT specifies the format of the file by its standard     file extension. For example, specify 'gif' for Graphics Interchange Format files. To see a list of supported formats, with their file  extensions, use the IMFORMATS function. If IMREAD cannot find a file  named FILENAME, it looks for a file named FILENAME.FMT.
FMT,应该使用你图片的格式替换!
 楼主| 发表于 2011-6-23 10:38:36 | 显示全部楼层
我改过了,可是还是不行。。。。。。
发表于 2011-6-27 14:44:50 | 显示全部楼层
把[X map] = imread(filename, FMT);换成[X map] = imread(filename, 'bmp');
并且读入图像找BMP格式的图像
 楼主| 发表于 2011-6-28 17:33:38 | 显示全部楼层
回复 4# renyidian
% 2d fft
Y = fftshift(Y);
% calculate radius
filt = SF > k0;
% show
figure(1);
clf reset;
colormap gray;
% plot image
subplot(2, 2, 1);
imagesc(L);
colorbar;
axis square;
xlabel('x');
ylabel('y');
% plot amplitude
A = abs(A);
A = log10(A);
subplot(2, 2, 2);
imagesc(fx, fy, A);
axis xy;
axis square;
subplot(2, 2, 3);
axis xy;
axis square;
% filtered image
subplot(2, 2, 4);
colorbar;
axis square;
xlabel('x');
ylabel('y');
figure ;
imshow(LNoise) ;
figure
imshow(L)
[X map] = imread(filename, 'bmp'); % read image
% 2d fft
Y = fftshift(Y);
% calculate radius
filt = SF > k0;
% show
figure(1);
clf reset;
colormap gray;
% plot image
subplot(2, 2, 1);
imagesc(L);
colorbar;
axis square;
xlabel('x');
ylabel('y');
% plot amplitude
A = abs(A);
A = log10(A);
subplot(2, 2, 2);
imagesc(fx, fy, A);
axis xy;
axis square;
subplot(2, 2, 3);
axis xy;
axis square;
% filtered image
subplot(2, 2, 4);
colorbar;
axis square;
xlabel('x');
ylabel('y');
figure ;
imshow(LNoise) ;
figure
imshow(L)
??? Undefined function or variable 'm'.
发表于 2011-7-11 22:49:33 | 显示全部楼层
学习,谢谢!!!!!!!
GMT+8, 2025-9-15 03:22 , Processed in 0.020402 second(s), 5 queries , Gzip On, Redis On.
