查看: 7723|回复: 8
[求助] some issue for VCO phase noise simulation by cadence spectre
发表于 2011-6-20 23:33:14 | 显示全部楼层 |阅读模式
Dear all,
I have some issue for VCO phase noise simulation by cadence spectre.
I had simulated a 250MHz VCO phase noise.
But this simulation result seems not correct even change another VCO structure.
it is correct for VCO frequency be tuned 2.5G.
Does it something wrong?
it is simulation result for transient dft (250MHz)
dft
dft
it is simulation result for Phase Noise waveform
PhaseNoise
PhaseNoise
Obviously it is not correction.
it is PSS setting
PSS1
PSS1
PSS2
PSS2
VCO is stable after 30ns
and maxstep is set 100p
it is PNOISE setting
PNOISE
PNOISE
The result shall correct that VCO frequency be increased to 2.5G.
Does it something wrong for simulation setting?
Thanks for your help.
发表于 2011-6-20 23:39:04 | 显示全部楼层
回复 1# cwcgo
    你是想说相噪奇差吗?那就把noise summary贴上来~
 楼主| 发表于 2011-6-20 23:47:49 | 显示全部楼层
回复 2# happygrass
hi, thanks for your reply.
I will upload noise summary tomorrow.
Thanks.
 楼主| 发表于 2011-6-21 09:22:49 | 显示全部楼层
回复 4# pcb-si.com
it is VCO phase noise & noise summary.
The summary result seems ok but phase noise waveform seems some has some issue.
thanks for help.
发表于 2011-6-21 09:35:57 | 显示全部楼层
等会说中文了再回答这种问题
发表于 2011-11-2 16:39:47 | 显示全部楼层
你的vco什么结构的?phase noise 怎么这么烂?
发表于 2011-11-2 20:37:24 | 显示全部楼层
Beat Frequency 不该是2.5e9吗?
发表于 2016-3-17 23:10:50 | 显示全部楼层
thanks
发表于 2016-8-16 16:32:41 | 显示全部楼层
GMT+8, 2025-12-29 20:45 , Processed in 0.022533 second(s), 4 queries , Gzip On, Redis On.
