查看: 4080|回复: 7
[求助] 求助一个简单网表
发表于 2011-6-12 13:35:42 | 显示全部楼层 |阅读模式
悬赏40资产未解决
完全没有接触过HSPICE,想要用HSPICE做一个纳米CMOS反向器动态功耗的分析,不知道有没有人能帮忙写个简单的网表文件。
      急求,好心人事事顺心,薪水哗哗的涨,谢谢啦~~~
额,下面是个网表文件(不是做动态功耗的这个),有谁可以用这个修改下来做动态功耗吗?
.subckt BD_BUF_B I O
*.PININFO I:B O:B VCC:B VSS:B
M+3 O N0 VSS VSS NM W=5.10000018e-6 L=499.9999987e-9
M+2 VSS I N0 VSS NM W=2.850000101e-6 L=499.9999987e-9
M+1 O N0 VCC VCC PM W=9.000000318e-6 L=499.9999987e-9
M+0 VCC I N0 VCC PM W=6.499999927e-6 L=499.9999987e-9
.ends
.subckt BD_BUF_B_drv
drv_VCC drv_VSS IO
M+3 O N0 drv_VSS drv_VSS NM W=5.10000018e-6 L=499.9999987e-9
M+2 drv_VSS I N0 drv_VSS NM W=2.850000101e-6 L=499.9999987e-9
M+1 O N0 drv_VCC drv_VCC PM W=9.000000318e-6 L=499.9999987e-9
M+0 drv_VCC I N0 drv_VCC PM W=6.499999927e-6 L=499.9999987e-9
.ends
.options
+relv=10u
+absv=1u
+relmos=10u
+reli=10u
+absi=1p
+absvdc=1u
+gmindc=1f
+co=300
+interp=1
+relh=10u
+absh=1p
+gmin=1f
+absmos=1p
+pivot=12
+relvdc=10u
+brief=1
+numdgt=5
+nomod=1
+nopage=1
+ingold=2
+alt999
* Global Net Declarations
.GLOBAL VCC Drv_VCC VSS Drv_VSS
.temp 25
.param VSS=0
.param VCC=4.5
.param Drv_VSS=0
.param Drv_VCC=4.5
.param load=4.43243e-13
.param idle=21 slope=0.1
.param vil=0.3 vih=0.7 viv=0.5
.param vol=0.3 voh=0.7 vov=0.5
vVSS VSS 0 0
vVCC VCC 0 4.5
vDrv_VSS Drv_VSS 0 0
vDrv_VCC Drv_VCC 0 4.5
.param step=0.01ns
*add the capacitance after the test output pin
cO O 0 load m=1
*call the driver cell before the input pins.
xBD_BUF_B_I_drv
drv_VCC drv_VSSBD_BUF_B_I_drv I_drv
BD_BUF_B_drv
*add the depend voltage source at the input pin
eI I 0 vol='v(I_drv)'
cI_drv I_drv 0 load_rtp m=1
*call the cell under test
xBD_BUF_B
I
O
BD_BUF_B m=1
* the logic stimulus waves.
*I
O
*0
*r
vBD_BUF_B_I_drv BD_BUF_B_I_drv 0 pwl(
+ '0+slope' VSS '0+slope+idle' VSS
+ '1*(idle+slope)+idle/2' VSS '1*(idle+slope)+dataslope+idle/2' VCC'1*(idle+slope)+dataslope+idle' VCC
.param idle=21ns load=5.31892e-15 slope=0.25ns dataslope=0.25nsload_rtp=0
.tran 0.01ns '1*(idle+slope)+idle+dataslope+idle/2' start='(1*(idle+slope)+idle/2)'
.measure
tran
s_I trig
v(I) val='vil*VCC' td='(1*(idle+slope)+idle/2)'
cross=1
+targ v(I) val='vih*VCC' td='(1*(idle+slope)+idle/2)'
cross=1
.measure
tran
s_O trig
v(O) val='vol*VCC' td='(1*(idle+slope)+idle/2)'
cross=1
+targ v(O) val='voh*VCC' td='(1*(idle+slope)+idle/2)'
cross=1
.measure
tran
d_I_O trig
v(I) val='viv*VCC' td='(1*(idle+slope)+idle/2)'
cross=1
+targ v(O) val='vov*VCC' td='(1*(idle+slope)+idle/2)'
cross=1
*integrate the current of vdd
*integrate the current of VCC
.measure tran VCC_cur integ I(vVCC) from='(1*(idle+slope)+idle/2)'to='1*(idle+slope)+idle+dataslope+idle/2'
*integrate the current of VSS
.measure tran VSS_cur integ I(vVSS) from='(1*(idle+slope)+idle/2)'to='1*(idle+slope)+idle+dataslope+idle/2'
.measure tran vddpow param='-VCC_cur*VCC-VSS_cur*VSS'
.print tran
v(O)
I(cO) v(I)
I(eI)
.alter run1
.param idle=21ns load=5.31892e-15 slope=0.25ns dataslope=0.25nsload_rtp=1.21848e-12
.alter run2
.param idle=21ns load=5.31892e-15 slope=0.25ns dataslope=0.25nsload_rtp=5.43591e-12
.alter run3
.param idle=21ns load=1.18233e-12 slope=0.25ns dataslope=0.25nsload_rtp=0
.alter run4
.param idle=21ns load=1.18233e-12 slope=0.25ns dataslope=0.25nsload_rtp=1.21848e-12
.alter run5
.param idle=21ns load=1.18233e-12 slope=0.25ns dataslope=0.25nsload_rtp=5.43591e-12
.alter run6
.param idle=21ns load=5.31892e-12 slope=0.25ns dataslope=0.25nsload_rtp=0
.alter run7
.param idle=21ns load=5.31892e-12 slope=0.25ns dataslope=0.25nsload_rtp=1.21848e-12
.alter run8
.param idle=21ns load=5.31892e-12 slope=0.25ns dataslope=0.25nsload_rtp=5.43591e-12
.end
 楼主| 发表于 2011-6-12 21:37:54 | 显示全部楼层
自己顶上去,真心求助。
发表于 2011-6-13 12:25:34 | 显示全部楼层
难度高!
 楼主| 发表于 2011-6-13 18:36:32 | 显示全部楼层
自己再顶下  跪求指教啊
 楼主| 发表于 2011-6-14 14:17:46 | 显示全部楼层
这么久了还是没人回答。。。。。。
 楼主| 发表于 2011-6-14 22:11:11 | 显示全部楼层
啊啊啊~~~谁能帮帮我啊  要自杀都。。。
发表于 2011-6-15 16:04:48 | 显示全部楼层
回复 7# 346035929
你资产才21信元,还悬赏40信元?
发表于 2011-6-15 16:07:28 | 显示全部楼层
为啥不用spectre来仿,当然用hspice应该也可以啊。将电源的电流保存下来就可以看动态功耗了啊。
GMT+8, 2025-12-30 08:47 , Processed in 0.026544 second(s), 7 queries , Gzip On, Redis On.
