查看: 2953|回复: 3
[招聘] amd 上海招聘 asic design verification engineer
发表于 2011-6-8 13:17:23 | 显示全部楼层 |阅读模式
AMD 上海研发中心招聘 ASIC design verification engineer
msn:jj_seu@hotmail.com
qq: 1317656040
简历发 jane2.jin@amd.com
MTS/Sr. ASIC Engineer:
Position Summary
- Participate IP and SoC level architecture definition, derive functional and design specifications and analyze feasibility of technical and architectures.
- Implement design with Verilog to achieve specification goals. Simulate and debug the codes in coding stage.
- Go through the FE design flow to deliver qualified netlist. Feedback to Physical Design team to help to close timing and check floorplan.
- Write ASIC specific part of test plan. Prove functional correctness from block level to SoC level
- Support FW/SW bring-up and debugging
- Working as the technical point of contact on the ASIC area.
- Maintain design environment, solve flow issues, and develop scripts to improve flow efficiency.
Essential Functions:
RTL, Verification, Testbench, SystemC, SystemVerilog, OVM
Essential Requirements/Qualifications:
- Proven ASIC / SoC Design / Verification Experience
- Must have strong background on IP development
Desired:
- Major in EE & CS
- Must be proficient in Verilog coding, debugging and modeling
- Should be familiar with Advanced C/C++/SystemVerilog, RTL coding techniques.
- PCIe, BIOS, ACPI experience would be an asset.
- Must be familiar with Design for verification Methodology (assertion based design strategies, code coverage, functional coverage, test plan, gate-level simulation, back-annotation etc.)
- Should be familiar with ASIC design flow, such as synthesis, DFT, timing analysis, ECO etc.
- Must be familiar with shell/perl/tcl programming in linux OS.
- Should have strong problem solving skills
- Good English hearing, speaking, reading and writing capabilities.
- Good communication skills
- Will be a big plus if having mass production tape‐out experience.
发表于 2011-6-8 15:44:28 | 显示全部楼层
要求不低。
发表于 2011-6-14 21:36:54 | 显示全部楼层
貌似 我符合这个要求
GMT+8, 2025-12-19 08:41 , Processed in 0.017473 second(s), 4 queries , Gzip On, Redis On.
