查看: 3903|回复: 5
[招聘] AMD 上海研发中心 招聘asic design verification 工程师
发表于 2011-6-7 17:57:50 | 显示全部楼层 |阅读模式
AMD 上海研发中心招聘 ASIC design verification engineer
msn:jj_seu@hotmail.com
qq: 1317656040
简历发 jane2.jin@amd.com
MTS/Sr. ASIC Engineer:
Position Summary
- Participate IP and SoC level architecture definition, derive functional and design specifications and analyze feasibility
of technical and architectures.
- Implement design with Verilog to achieve specification goals. Simulate and debug the codes in coding stage.
- Go through the FE design flow to deliver qualified netlist. Feedback to Physical Design team to help to close timing and
check floorplan.
- Write ASIC specific part of test plan. Prove functional correctness from block level to SoC level
- Support FW/SW bring-up and debugging
- Working as the technical point of contact on the ASIC area.
- Maintain design environment, solve flow issues, and develop scripts to improve flow efficiency.
Essential Functions:
RTL, Verification, Testbench, SystemC, SystemVerilog, OVM
Essential Requirements/Qualifications:
- Proven ASIC / SoC Design / Verification Experience
- Must have strong background on IP development
Desired:
- Major in EE & CS
- Must be proficient in Verilog coding, debugging and modeling
- Should be familiar with Advanced C/C++/SystemVerilog, RTL coding techniques.
- PCIe, BIOS, ACPI experience would be an asset.
- Must be familiar with Design for verification Methodology (assertion based design strategies, code coverage, functional
coverage, test plan, gate-level simulation, back-annotation etc.)
- Should be familiar with ASIC design flow, such as synthesis, DFT, timing analysis, ECO etc.
- Must be familiar with shell/perl/tcl programming in linux OS.
- Should have strong problem solving skills
- Good English hearing, speaking, reading and writing capabilities.
- Good communication skills
- Will be a big plus if having mass production tape‐out experience.
发表于 2011-6-9 09:56:24 | 显示全部楼层
回复 1# jj_seu
楼主是东南4系还是6系的啊?
发表于 2011-6-9 10:39:15 | 显示全部楼层
回复 1# jj_seu
    楼主是东南4系还是6系的啊?
发表于 2011-6-9 10:39:59 | 显示全部楼层
回复 1# jj_seu
    楼主是东南4系还是6系的啊?
发表于 2011-6-9 22:40:05 | 显示全部楼层
有点兴趣!
发表于 2011-6-14 18:35:27 | 显示全部楼层
感觉这个更偏向于验证这一块。
GMT+8, 2025-12-24 17:53 , Processed in 0.026673 second(s), 8 queries , Gzip On, Redis On.
