查看: 7825|回复: 2
[求助] candence仿真问题
发表于 2011-6-2 16:20:10 | 显示全部楼层 |阅读模式
以前电路能够仿真,但今天仿真时“滴”的响一声没有出现波形。不知为什么。如下:
Command line:
    /home/eda/mmsim61/tools.lnx86/spectre/bin/32bit/spectre input.scs  \
        +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre1_3579_3 -format sst2 -raw ../psf +lqtimeout  \
        900 -maxw 5 -maxn 5
spectre pid = 5607
Loading /home/eda/mmsim61/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so ...
Loading /home/eda/mmsim61/tools.lnx86/cmi/lib/4.0/libnortel_sh.so ...
Loading /home/eda/mmsim61/tools.lnx86/cmi/lib/4.0/libphilips_sh.so ...
Loading /home/eda/mmsim61/tools.lnx86/cmi/lib/4.0/libsparam_sh.so ...
Loading /home/eda/mmsim61/tools.lnx86/cmi/lib/4.0/libstmodels_sh.so ...
spectre (ver. 6.1.0.151 -- 26 May 2006).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
Simulating `input.scs' on localhost.localdomain at 1:13:55 AM, Thur Jun 2, 2011.
Using new Spectre Parser.
Circuit inventory:
              nodes 9
          equations 12
            bsim3v3 10
           resistor 2
            vsource 3
Entering remote command mode using MPSC service (spectre, ipi, v0.0, spectre1_3579_3, ).
AC Analysis `ac': freq = (100 uHz -> 100 Hz)
    ac: freq = 173.8 uHz      (4 %), step = 41.95 uHz       (2 %)
    ac: freq = 302 uHz        (8 %), step = 72.91 uHz       (2 %)
    ac: freq = 691.8 uHz     (14 %), step = 167 uHz         (2 %)
    ac: freq = 1.202 mHz     (18 %), step = 290.3 uHz       (2 %)
    ac: freq = 2.754 mHz     (24 %), step = 664.9 uHz       (2 %)
    ac: freq = 4.786 mHz     (28 %), step = 1.156 mHz       (2 %)
    ac: freq = 10.96 mHz     (34 %), step = 2.647 mHz       (2 %)
    ac: freq = 19.05 mHz     (38 %), step = 4.6 mHz         (2 %)
    ac: freq = 43.65 mHz     (44 %), step = 10.54 mHz       (2 %)
    ac: freq = 75.86 mHz     (48 %), step = 18.31 mHz       (2 %)
    ac: freq = 173.8 mHz     (54 %), step = 41.95 mHz       (2 %)
    ac: freq = 302 mHz       (58 %), step = 72.91 mHz       (2 %)
    ac: freq = 691.8 mHz     (64 %), step = 167 mHz         (2 %)
    ac: freq = 1.202 Hz      (68 %), step = 290.3 mHz       (2 %)
    ac: freq = 2.754 Hz      (74 %), step = 664.9 mHz       (2 %)
    ac: freq = 4.786 Hz      (78 %), step = 1.156 Hz        (2 %)
    ac: freq = 10.96 Hz      (84 %), step = 2.647 Hz        (2 %)
    ac: freq = 19.05 Hz      (88 %), step = 4.6 Hz          (2 %)
    ac: freq = 43.65 Hz      (94 %), step = 10.54 Hz        (2 %)
    ac: freq = 75.86 Hz      (98 %), step = 18.31 Hz        (2 %)
Accumulated DC solution time = 20 ms.
Intrinsic ac analysis time = 10 ms.
Total time required for ac analysis `ac' was 30 ms.
modelParameter: writing model parameter values to rawfile.
element: writing instance parameter values to rawfile.
outputParameter: writing output parameter values to rawfile.
designParamVals: writing netlist parameters to rawfile.
primitives: writing primitives to rawfile.
发表于 2011-6-2 16:31:38 | 显示全部楼层
你的output里面是怎么写的
 楼主| 发表于 2011-6-2 17:03:59 | 显示全部楼层
回复 2# Langrange
    奥。对了,是output问题。谢谢了。。。
GMT+8, 2025-12-25 01:55 , Processed in 0.019345 second(s), 3 queries , Gzip On, Redis On.
