查看: 6057|回复: 10
[求助] 致命错误-synopsysDC200809如此提示,求大神解决
发表于 2011-5-30 22:29:37 | 显示全部楼层 |阅读模式
synopsysDC200809运行到一半,突然停止,出现以下错误(红色部分)。有谁遇到过?能告知什么原因及怎么解决吗?
Abort at 949
The tool has just encountered a fatal error:
If you encountered this fatal error when using the most recent
Synopsys release, submit this stack trace and a test case that
reproduces the problem to the Synopsys Support Center by using
Enter A Call at
http://solvnet.synopsys.com/EnterACall.
* For information about the latest software releases, go to the Synopsys
  SolvNet Release Library at
http://solvnet.synopsys.com/ReleaseLibrary.
* For information about required Operating System patches, go to
http://www.synopsys.com/qrsc.
* For instructions for creating, packaging, and sending a test case, go to
http://www.synopsys.com/testcase.
Fatal: Internal system error, cannot recover.
Release = 'B-2008.09'  Architecture = 'linux'  Program = 'dc_shell'
'232411252 232411831 1152000 232760541 167677830 167724047 167734258 167791474 153866337 153867150 154212907 153388598 153399185 153410420 150183711 149199923 232150466 233667322 233673402 233674240 232118198 232130577 232150466 233667322 233673402 233674240 232118198 232130577 232150466 233667322 233673402 233674240 232143309 232143870 145861036 145861181 145879567 145881773 145883036 134620136 134606634 9862102'
发表于 2011-5-31 08:19:16 | 显示全部楼层
系统问题,换成redhat就行了,我的ubuntu就遇到过
发表于 2011-6-2 20:31:37 | 显示全部楼层
OS的问题,最好是用RHEL4.x的
发表于 2011-6-2 23:01:31 | 显示全部楼层
系统问题我也遇到过
发表于 2011-7-22 14:50:41 | 显示全部楼层
我也遇到了,如果是无版图的话 能不能有其他方法解决呢?
发表于 2011-7-22 15:22:29 | 显示全部楼层
OS error
发表于 2011-7-22 19:54:36 | 显示全部楼层
XUEXI LE
发表于 2011-9-14 21:08:10 | 显示全部楼层
请问dc2008本来就不包含design_analyzer吗?
我的dc2008安装后dc,dv都可以正常启动,但是就是启动design_analyzer时
说没有这个命令。
发表于 2013-5-2 11:53:50 | 显示全部楼层
我也遇到楼主的问题,请问楼主是怎么解决的呢
发表于 2013-5-4 11:28:09 | 显示全部楼层
系统问题的根源是什么?
GMT+8, 2025-12-14 00:16 , Processed in 0.022644 second(s), 7 queries , Gzip On, Redis On.
