查看: 4925|回复: 7
[资料] IEEE TRANSACTIONS ON CIRCUITS AND SYSTEMS-六月份-绝对超值
发表于 2011-5-28 15:17:08 | 显示全部楼层 |阅读模式
IEEE TRANSACTIONS ON CIRCUITS AND SYSTEMS JUNE 2011
1.8T Differential SRAM With Improved Noise Margin for Bit-Interleaving in 6
2.Synchronization in Networks of Diffusively Time-Delay Coupled (Semi-)Passive Systems
3. Positive Linear Systems Consisting of $n$ Subsystems With Different Fractional Orders
4.A 5 Gb Automatic Within-Pair Skew Compensator for Differential Data in 0.13 $mu{hbox{m}}$ CMOS
5. A 10-bit 100-MS 4.5-mW Pipelined ADC With a Time-Sharing Technique
6. A 14 b 23 MS 48 mW Resetting $Sigma Delta$ ADC
7. A DCVSL Delay Cell for Fast Low Power Frequency Synthesis Applications
8. A Low-Cost VLSI Architecture for Robust Distributed Estimation in Wireless Sensor Networks
9. A Multidrop Bus Design Scheme With Resistor-Based Impedance Matching on Nonuniform Impedance Lines
10. Adaptive Blind Background Calibration of Polynomial-Represented Frequency Response Mismatches in a Two-Channel Time-Interleaved ADC
11. Adaptive Synchronization of a Class of Uncertain Complex Networks Against Network Deterioration
12. Analysis, Design, Modeling, and Implementation of an Active Clamp HF Link Converter
13. Controlling Chaos in a Memristor Based Circuit Using a Twin-T Notch Filter
14. Discrete-Time, Linear Periodically Time-Variant Phase-Locked Loop Model for Jitter Analysis
15.Efficient Design and Implementation of Variable Fractional Delay Filters Using Differentiators
16. High-Efficiency Processing Schedule for Parallel Turbo Decoders Using QPP Interleaver
17. Impacts of NBTI PBTI on Timing Control Circuits and Degradation Tolerant Design in Nanoscale CMOS SRAM
18. In-Place FPGA Retiming for Mitigation of Variational Single-Event Transient Faults
19. Lag Quasi-Synchronization of Coupled Delayed Systems With Parameter Mismatch
20. Pathological Element-Based Active Device Models and Their Application to Symbolic Analysis
21. Realization of High Octave Decomposition for Breast Cancer Feature Extraction on Ultrasound Images
22. Steady-State Simulation and Optimization of Class-E Power Amplifiers With Extended Impedance Method
23. The Sampling Theorem With Constant Amplitude Variable Width Pulses
24. Computation of Steady-State Oscillations in Power Converters Through Complementarity
8T Differential SRAM With Improved Noise Margin for Bit-Interleaving in 6.pdf
2.4 MB, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_8aeea3616ce51425890e4a893d87c5f6.pdf
3.19 MB, 下载次数: 16 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 10-bit 100-MS 4.5-mW Pipelined ADC With a Time-Sharing Technique.pdf
1.36 MB, 下载次数: 50 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 14 b 23 MS 48 mW Resetting $Sigma Delta$ ADC.pdf
1.53 MB, 下载次数: 34 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A DCVSL Delay Cell for Fast Low Power Frequency Synthesis Applications.pdf
2.54 MB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_cf4a21f111bc35a1a4ed25824e54cd28.pdf
1.91 MB, 下载次数: 17 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_21a7f9668e9d86b92c291fce3746c2e7.pdf
2.37 MB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_1c2c7d1eba71329fbe90a2bec523e878.pdf
1.62 MB, 下载次数: 17 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_8540d834eab7098547529297c010b7fe.pdf
1.18 MB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Analysis, Design, Modeling, and Implementation of an Active Clamp HF Link Converter.pdf
2.74 MB, 下载次数: 15 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Computation of Steady-State Oscillations in Power Converters Through Complementarity.pdf
1.92 MB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Controlling Chaos in a Memristor Based Circuit Using a Twin-T Notch Filter.pdf
1.91 MB, 下载次数: 24 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_8b1139b72033541e4696937d92533ae8.pdf
3.63 MB, 下载次数: 20 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_7f186e384b2e4f0ab71e15dd62f70e86.pdf
2.62 MB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
High-Efficiency Processing Schedule for Parallel Turbo Decoders Using QPP Interleaver.pdf
2.02 MB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_6908cf66017d433d7b26b87287154c1b.pdf
1.27 MB, 下载次数: 15 , 下载积分: 资产 -2 信元, 下载支出 2 信元
In-Place FPGA Retiming for Mitigation of Variational Single-Event Transient Faults.pdf
2.14 MB, 下载次数: 7 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Lag Quasi-Synchronization of Coupled Delayed Systems With Parameter Mismatch.pdf
4.15 MB, 下载次数: 6 , 下载积分: 资产 -3 信元, 下载支出 3 信元
abbr_b496b3916abb58027bda7c05ec172cdc.pdf
2.14 MB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Positive Linear Systems Consisting of $n$ Subsystems With Different Fractional Orders.pdf
1.67 MB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_e325f1889fe2bb963bfe826f89a2514b.pdf
3.28 MB, 下载次数: 9 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_f102928a84dcb000dfde73edd19e7d9b.pdf
1.85 MB, 下载次数: 10 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Synchronization in Networks of Diffusively Time-Delay Coupled (Semi-)Passive Systems.pdf
3.25 MB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
The Sampling Theorem With Constant Amplitude Variable Width Pulses.pdf
2.12 MB, 下载次数: 15 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-5-28 16:03:51 | 显示全部楼层
楼主,请把这些文件压成大的文件包,谢谢!!1
发表于 2011-5-30 12:31:43 | 显示全部楼层
打包吧
发表于 2011-5-30 13:18:58 | 显示全部楼层
bu cuo, thanks
发表于 2016-1-8 07:01:40 | 显示全部楼层
thnx!
发表于 2018-5-17 21:40:35 | 显示全部楼层
谢谢分享
发表于 2021-2-5 11:28:36 | 显示全部楼层
楼主,打个包吧,谢谢
发表于 2021-2-22 23:22:40 | 显示全部楼层
感謝無私分享!
GMT+8, 2025-12-26 04:24 , Processed in 0.031689 second(s), 8 queries , Gzip On, Redis On.
