查看: 2430|回复: 6
[资料] High-speed bus debug and validation test challenges
发表于 2011-5-21 02:38:18 | 显示全部楼层 |阅读模式
Abstract
Emerging high-speed bus technologies are presenting new
test challenges for engineering device debug and validation.
These challenges include: Multi-gigabit operating speeds,
multiple-time domains, encoding schemes, non-deterministic
data, DUT-synchronous clocking modes, and SerDes
transceivers with tracking receivers. A key aspect of debug
and validation is the requirement for at-speed functional
testing, requiring high-bandwidth interfacing to maintain
signal integrity at multi-Gbps data rates. Further, these new
communications-like buses require quantification of timing
parameters such as Bit Error Rate, eye opening, and jitter.
Conventional test methods may no longer yield meaningful
results or even be applicable.
As high-speed bus technologies proliferate, they are
expected to replace traditional parallel bus interfaces. New
features and architectural changes are integral to engineering
tester solutions for evaluating devices that use high-speed bus
technologies. This paper introduces an advanced pattern
architecture concept that incorporates sophisticated memory
management optimized for data collection and for
applications such as optical probing and DFT-based
operations. New high-speed bus test challenges and potential
solutions, pertaining to engineering debug and validation test,
are also addressed.
High-speed bus debug and validation test challenges.pdf (615.63 KB , 下载次数: 52 )
发表于 2011-5-24 13:04:22 | 显示全部楼层
非常感谢
发表于 2011-5-24 14:47:44 | 显示全部楼层
有中文版没
发表于 2011-5-24 22:58:33 | 显示全部楼层
xie xie xie xie xie xie
发表于 2011-9-4 10:17:14 | 显示全部楼层
Thanks
发表于 2016-9-12 18:22:28 | 显示全部楼层
thank for your sharing
发表于 2018-9-24 07:21:42 | 显示全部楼层
謝謝分享
GMT+8, 2025-12-24 23:02 , Processed in 3.769322 second(s), 6 queries , Gzip On, Redis On.
