楼主: disth
[资料] @ds2011 win path by LONG
发表于 2011-5-2 11:46:03 | 显示全部楼层
密码呢???????//
发表于 2011-5-2 12:11:39 | 显示全部楼层
这个很好!
发表于 2011-5-2 12:47:28 | 显示全部楼层
thanks!!!
发表于 2011-5-2 14:22:10 | 显示全部楼层
回复 113# feyd_rautha
Do you mind telling about what you did to ads2011? It would be best to detail step by step so as to be able to check carefully into your operations.
发表于 2011-5-2 17:49:50 | 显示全部楼层
谢谢分享!!!
发表于 2011-5-2 18:58:46 | 显示全部楼层
kankan
发表于 2011-5-2 20:17:36 | 显示全部楼层
谢谢!
发表于 2011-5-2 20:50:23 | 显示全部楼层
nice
thanks a lot for your sharing.
发表于 2011-5-2 22:22:54 | 显示全部楼层
回复 128# DHB1223
    Setup--Crack as the txt(.dll and env etc )
build a project(workspace in 2011), build a schematic, two terms , S parameters simulate. failed - -!
It tells me a expired license.
All!
发表于 2011-5-2 23:18:19 | 显示全部楼层
回复 133# feyd_rautha
It is weird why it did not work in your side as I noticed some have been able to run it successfuly.
You are adivsed not to build project by yourself, instead to open a example project and try to run it to see whether it works.
GMT+8, 2025-12-18 00:20 , Processed in 0.019191 second(s), 3 queries , Gzip On, Redis On.
