查看: 4984|回复: 3
[招聘] 【招聘】全球著名美资IC公司LSI上海研发中心2011年热招职位
发表于 2011-4-29 13:23:13 | 显示全部楼层 |阅读模式
欢迎有志之士加入!如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.也可加我msn;zql975504@hotmail.com
有意者,请将简历发至:Tracey.zheng@lsi.com
1.
Analog Modeling (New!!!)
Job Description
A qualified applicant for this position would be responsible to work within a Product
Development Team to create behavioral models for Read Channel analog design blocks.
Close interaction with the analog and digital design teams is required.
Full chip verification of read channel designs which incorporate the analog models is required.
Ability to use both digital and analog simulators is required.
Must be willing to follow a disciplined design approach and to work closely with a multilocation,
international team.
Excellent teamwork and communication skills are required
Requirements/Qualifications (Education)
Minimum of 3 years analog IC design and/or modeling experience in a product
development environment
Experience with analog and digital Cadence-based simulation tools and SV/AMS modeling language
Strong written and verbal communication skills
Desired:
Read channel application experience
2.
Test Engineer
JOB DESCRIPTION:
- To support prototype and production releases of new products. Manage debug of test
program and hardware and meet product release schedules.
- Support test program development for implementing changes in new test methodologies
for test coverage improvement.
- Pursue Design for Test initiatives to optimize testability and achieve test cost reduction via
test time reduction and multiple site test solutions for production release.
- Support test chip test development and characterization of new IP used in LSI products.
PREFERRED EXPERIENCE:
- University graduate students with top scores in GPA
- Prior working experiences in the semiconductor industry field, specially in either IDM,
Fabless, or Foundry environment
- ATE programming skills would be essential
- C++ and/or Perl programming skills
3.
Program Manager (New!!!)
Responsibilities:
- Project Definition:
Work with design/validation managers, program managers & product managers to create the baseline plan or record or POR (scope, schedule, budget, etc.) for the program
Develop project plans & risk mitigation plans for design and silicon validation
Establish strong program management for design and validation, including the right processes and tools to facilitate planning and execution.
Coordinate and facilitate the set up of the project team in cooperation with other functional groups
- Project Execution:
Setup & moderate regular project review meetings across time zones (US/Asia)
Act as main interface to other groups within the company; establish and maintain effective communication management
Drive common stage gate process as well as quality/milestone checklists to enable superior product execution and quality
Implement & drive effective plan of record (POR) change management
Drive development & implementation of business critical metrics
Drive implementation & adoption of key program management tools
Maintain and measure project progress against plan
Support ongoing risk/issue management
FacilitateProject Lessons Learned (internal and with the customer)
General Program management:
Partner with PMO, design managers and leadership team in driving efficient & common program management practices & capabilities
Support PMO in monthly or quarterly program reviews
Requirements:
- BSEE or equivalent, Masters preferred
- Significant program management experience, relating to IP/IC design and/or validation for complex integrated circuits and electronics products
- Experience in leading/program managing large, complex, mission-critical IP and/or silicon product development and/or validation involving cross-geographic, international teams in the U.S. and Asia
- Experience/exposure to FW/Sys dev & FPGA emulation a plus
- International program management experience desirable; fluency in English (writing and speaking) very important
- Preferred location is Shanghai, China
A good tops-down and bottoms-up perspective on what is required to effectively take a complete solution to market
4.
Preamp Analog Mixed Signal Physical Design (Layout) Engineer(New!!!)
Job Description
LSI's Storage Peripherals Group is looking for an experienced IC physical design engineer to join
the pre-amplifier design team. As a preamp physical design (layout) engineer you will work
closely with circuit design to implement high-speed custom analog designs and develop mask
layouts for customer products. You will join a cross-functional team responsible for developing
leading edge high-speed magneto electronic read/write IC products that ultimately achieve high
volume production
- Layout high speed analog and mixed-signal custom chips for the hard disk drive industry
- Work directly with a team of engineers to determine floor plan, routing and I/O requirements
for preamp IC's
- Perform IC design rule and connectivity verification and drive products through mask release
flows.
- Contribute to methodology improvements to increase layout and verification efficiency
- Bachelor's degree in Electrical Engineering (or related field) or equivalent
experience\Minimum three to five years experience in custom analog IC physical design
- Experience with schematic-driven layout, floor planning, chip level routing, design for
manufacturing and design rule and connectivity verification is required
- Experience using Cadence Virtuoso XL and VCAR router preferred
- Familiarity with both analog and digital layout tools and flows, circuit design concepts and IC
manufacturing processes desired
6.
Analog design engineer (New!!!)
Job Description
Develop and design complex analog and mixed-signal circuitries for high-speed Serdes core and products
Simulate mixed signal circuits with EDA tools to confirm functionalities and performance of these circuits.
Create design documents based on the mixed-signal design flow.
Supervise physical layouts of analog circuitries.
Participate in silicon validation of SerDes cores
MSEE/PhD with at least 5 years of direct experiences in analog designs for high speed
SerDes, such as decision feedback equalizer in analog and digital domain, low-jitter and widetuning
range frequency synthesizer, clock and data recovery circuit, linear equalizer, analogto-digital converter, high speed amplifier .
Knowledge in communication system and SerDes is a plus
7.
Verification Engineer –Shanghai (New!!!)
Job Responsibilities
Duties will include working with a Verification Team to develop reusable block and system level verification environment using high level verification language to support ASIC development. Review RTL architectural and implementation specifications. Develop test plan, create stimulus drivers, monitors, reference models, scoreboards, protocol checkers to verify function and performance of advanced multiprotocol networking ASICs. Define and develop application tests required to verify ASICs meet functional and performance goals. Define and implement functional coverage plans. Define and implement code coverage plans. Develop testing and regression methodologies for new verification flow. Coordinate test plan implementation and regressions with remote team. Incorporate reusability into all aspects of the verification environment. Develop/maintain/enhance environment tools/scripts/makefiles. LSI Corporation is a leading provider of innovative silicon, systems and software technologies that enable products which seamlessly bring people, information and digital content together. We offer a broad portfolio of capabilities and services including custom and standard product ICs, adapters, systems and software that are trusted by the world's best known brands to power leading solutions in the storage and networking markets. We value the diversity of our people. LSI is an Equal Opportunity Employer.
Functional/Industry Knowledge:
Required: - ASIC Design and Verification skills and experience - Knowledge of high level verification languages such as SystemVerilog - Knowledge of data and telecommunication networking - Scripting skills, such as Shell, Perl and TCL - Good written and verbal communication skills Education/Certifications: Required Degree: MS Preferred Major: Electrical Engineering or related discipline
8.
Digital Design Engineer –Shanghai (New!!!)
Work with a product development team on networking IC design, verification and post-silicon validation. The networking ICs we are involved are advanced multi-core networking processors, multi-service processors, multi-core media and baseband processors that target for wireline and wireless networking infrastructure. LSI Corporation is a leading provider of innovative silicon, systems and software technologies that enable products which seamlessly bring people, information and digital content together. We offer a broad portfolio of capabilities and services including custom and standard product ICs, adapters, systems and software that are trusted by the world's best known brands to power leading solutions in the storage and networking markets. We value the diversity of our people. LSI is an Equal Opportunity Employer.
Functional/Industry Knowledge: Required: - Knowledge of digital logic design - Knowledge of hardware design language and/or high level verification language - Knowledge of data and telecommunication networking - Good written and verbal communication skills Preferred: - Digital IC design and/or Verification experience - Familiar with System Verilog
9.
(New!!!)
Will be responsible for design and verification of functional blocks for various Networking related ASIC
Functional/Industry Knowledge: Required: 1+ years ASIC design required. Networking experience a plus. Fluent in Verilog HDL and ASIC design flows
EDUCATION: Master
10.
Preamp Analog/Mixed Signal Design Engineer-Shanghai
JOB DESCRIPTION:
- Design high speed analog and mixed-signal integrated circuits within custom chips for the
- Work directly with customers to determine system requirements, write specifications and
guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the
functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test,
yield, characterization, reliability analysis, qualification and release to manufacturing
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to
join the pre-amplifier design team. At LSI we are committed to innovation and industry
leadership. We develop advanced high-speed magneto electronic read/write IC architectures
as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for
hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies.
Team members support the entire product life cycle beginning with design and moving through
test, qualification, release to production and ramp to volume.
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- Minimum three to five years experience in discrete, transistor level analog circuit design
- Experience with analog and mixed signal IC product design, integration and verification is
required
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
11.
Digital IC Design Engineer-Shanghai
JOB DESCRIPTION:
- Working with an Architecture/Algorithm Development Team to finalize system architecture
for optimal implementation of digital signal processing algorithms, including architectural
definition and tradeoffs, die size estimation.
- Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification,
formal verification and static timing analysis.
- Perform some transistor level high speed digital integrated circuit design various cells and
blocks within custom chips for the hard disk drive industry. Examples of cells and blocks
include multiplexors, adders, multipliers, dividers, specific functional macro blocks,
- Work very closely with physical design engineers from floorplan through final parasitic
extraction to ensure smallest area and highest performance possible.
- Communicate effectively within a global business environment (must be proficient in both
spoken and written English)
- Experience in logic design, synthesis, static timing analysis, and verification
- Experience with ASIC EDA tools used in synthesis, simulation, static timing analysis, and
formal verification
- Experience in developing simulation and verification test benches
- Knowledge of Verilog/VHDL design languages
- Excellent technical troubleshooting and demonstrated problem solving skills
- Must be willing to follow a structured design approach including design for reuse and
provide thorough design documentation
12.
Read Channel Verification Engineer-Shanghai
JOB DESCRIPTION:
As a member of the Read Channel team, candidate must be willing to work as an extended
member of the design team. Duties will include functional verification of Storage read
channel mixed-signal IP. Candidate will be expected to contribute to design and development
of System Verilog based verification environment and will be responsible for verification
closure of block/chip/system level functions for mixed signal based IP. Experience with
System Verilog and functional coverage methodologies are required. Must be willing to
follow a disciplined verification methodology and to work closely with a multi-location,
international design team. Excellent teamwork and communication skills are required.
BSEE with 3-5+ years of design and/or verification experience required, MSEE preferred.
Required knowledge and skills:
- Expertise in System Verilog required
- Good understanding of Digital Signal Processing
- Good understanding of Analog and Digital Circuits
- Very good analytical/debugging skill
- Good verbal and written communication skills
Desirable skills:
- Knowledge of Verilog-AMS, Perl
- Knowledge of verification methodologies including functional coverage and constrained
random testing
- Knowledge of VLSI design flows & DFT
- Familiarity of high level programming language
- Experience working with globally distributed team management
- Experience in Supervising and mentoring Validation engineers
13.
ASIC Customer Engineer-Shanghai
The Customer Design Engineer is a challenging and cutting-edge position working with LSI
internal methodology and foundation IP development teams to support complex ASIC designs
for either external tier one customers or internal ASSP programs.
As an integral member of the customer design engineering team, the ASIC Customer Engineer
has responsibility for a wide range of tasks, including chip floor planning, place and route,
timing analysis, signal integrity, test, and design verification.
Responsible for support and completion of designs from customer provided RTL or Gate level
netlist using the latest LSI technologies.
Design completion tasks include
- Presales Support (die size support, memory generation, address customer questions and
concerns.)
- RTL Analysis & Synthesis
- Physical Design Implementation (bonding, floor planning, power structure insertion, place
and route, timing closure) using Synopsys Astro or ICC tools
- Test insertion using Mentor, LogicVision, or Virage tools
- Formal Verification (Verplex or Formality)
- Static Timing Analysis (Primetime and Primetime SI)
- Cross talk analysis
- Power verification
- DRC & LVS
Overtime, all ASIC customer engineers within the design center are expected to develop the
skills to be able to do most of the tasks described above in this role. Candidates having strong
skill sets one or more of the following areas should apply:
RTL Analysis/Synthesis/STA: The ideal candidate should have strong skills for the front-end of
design implementation which includes RTL Analysis, Synthesis Strategies, and STA setup for
complex ASIC environments. This would include strategies for power management.
or
Physical Design Implementation: The ideal candidate should be strong in either the Physical
Design which includes floor planning, design closure, & STA. Having strong DRC & LVS skills
are a plus. Strong Synopsys Astro/ICC experience a plus. Having strong Mentor Calibre skills
a plus.
or
5+ years experience in ASIC design and implementation. Familiar with Verilog RTL coding,
Verilog Simulators (NC or VCS) , Synopsys Design Compiler, Synopsys ICC Physical design
tools, PrimeTime for Static Timing Analysis, Mentor FastScan, LogicVision, Verplex (or
Formality), and scripting. The ideal candidate should have completed at least one successful
ASIC or ASSP tapeout. Successful tape out using Synopsys Astro or ICC considered a strong
plus. Experience in working with customers desired. Experience in working with and
debugging prototypes considered a strong plus. Knowledge and hands on use of test insertion
/ vector generation / verification a plus. Some experience with Signal integrity a bonus. Must
possess excellent communication skills; be able to effectively communicate with other
members of the design team, supporting organizations, and management.
BS/MS Electrical, Computer Engineering or Equivalent.
14.
System Applications Engineer –Shanghai/Shenzhen
Job Description
This is a Software Systems Applications Engineering position that involves the development and support of reference applications and API/FPI software for our customers. Software development includes creation of applications software for LSI multicore processor configurations using runtime API software, development of data path processing and forwarding software. Software support includes providing technical help on integrating LSI supplied application software with customer systems, LSI supplied SDE (Software Development Environment), reviewing customer application code, creating debugger APIs, simulator maintenance, and contributing to system software API testing. Customer interaction includes both pre-sales activities and issue debugging during development phases. Ability to work well with a variety of people and disciplines is required. Travel to customer sites is expected. Excellent communications skills in both Chinese and English are required
- Minimum of 5 years software Engineering experience in a data networking or telecom product development. Focused on multicore processor microcode and API device driver with C on RTOS(Linux, VxWorks)
- Familiar with network architectures and applications, traffic management and resource management algorithms and function
- Knowledge of multicore processor and wireline (ATM, TCP/IP, MPLS, PPP, Gigabit/Fast Ethernet), wireless (NodeB, RNC, GGSN) networking protocols
- Familiar with Linux and VxWorks OS
- Excellent problem solving and communication skills
- Experience with writing documents (data-sheet, application-notes, etc.)
Desired: - software/hardware experience in Network Processor and/or multicore processor, e.g. PowerPC - customer support experience - knowledge of interface,e.g. PCI-E bus, GE, RapidIO Education/Certifications Required Degree: BS Preferred Degree: MS Preferred Major: MSEE or MSCS
15.
Wireless System Architect-Shanghai
Job Description
- Project management, DOE, 6Sigma
16.
Sales Account Manager-Shanghai
Job Description
Identify and develop new opportunity as well as manage existing business in global accounts,
implement sales strategies to achieve design win and revenue goals;
Aggressively promote LSI networking products to global accounts to drive
strategic design wins and build strategic partnership;
Communicate with internal team and customer closely to resolve commercial, technical,
quality, and delivery issues to satisfy customer expectation;
Establish and maintain good relationship with customer R&D, marketing and procurement
team;
Get visibility on customer market dynamic and manage booking and billing forecast
accordingly.
Specific Knowledge/Experience
Bachelor Degree at E.E, and M.S. Degree preferred;
Minimum 5 years' working experience in Semiconductor/Telecom sales;
Good communication skill, good at spoken and written English;
Be willing to work aggressively, passionately and diligently to achieve challenging goal;
It’s preferred to support Huawei before.
17.
Technical Advisor-Shanghai
Job Description
-Responsible for driving frame work as well as key initiatives that are sponsored by Managing
Director’s office. Responsible to manage action item(s), closure of various forum meetings that
the Managing Director intends to attend or will be attending and interact / work closely with the
China Management Team (CMT) and the operations staff. Will be the sounding board for various
management presentations for the Managing Director’s office. -Drive Bi-weekly meetings with
operations senior management team and ensure bug closure follow ups via Remedy system
(Time bound training on Remedy will be provided). Encapsulate the data within framework as per
guidance from Managing Director -Driving and proposing, documenting important procedures that
would help manage the China intranet for various initiatives and review all paperwork prior to
Managing Director’s reviews corporate signatures and legal. -Required to take initiative to
manage monthly Managing Director’s newsletter content management, follow through for
accuracy of rewards, recognitions & patents disclosure data and arrange / coordinate logistics of
visiting Executive staff(s) agenda and travel. -Orchestrate manager(s) / management off-site
agendas and action item follow through, along with Managing Director’s budget and help alert
topics from China budget. Track various metrics on monthly basis as per guidance from
managing director and over time grow to be frameworks expert (for R&D metrics).
- Minimum 7 year of industry experience is a must with desirable program management
experience of supporting either the CEO or Managing Director with a Bachelors or Masters
Degree in communication, finance or Marketing. A bachelor in engineering is highly desirable.
- Good communication and presentation skills with an expertise in excel and power point is a
must. Excellent email etiquettes along with good work ethics, management experience and a flair
for program management. Proven track record of managing programs in the past is desirable.
 楼主| 发表于 2011-5-6 13:54:37 | 显示全部楼层
大家如果有什么问题,尽管问啊。。。:-)
 楼主| 发表于 2011-5-6 13:56:45 | 显示全部楼层
欢迎大家推荐啊!目前我们有很多Sr. Verification Engineer的职位
发表于 2011-5-9 21:04:03 | 显示全部楼层
回复 3# yulingyanyuyu
    你好,我想问下,贵公司模拟部分主要做什么
GMT+8, 2025-12-20 10:38 , Processed in 0.072981 second(s), 6 queries , Gzip On, Redis On.
