楼主: cp20
[求助] DC综合产生的SDF文件的hold time值为负数
发表于 2012-6-13 10:56:12 | 显示全部楼层
回复 9# 混乱三千年
    假如我p&r后···sdf 里面的cell还是有负值怎么搞,但是我p&r的hold time 明明满足了啊··高手··求解!
# ** Error: (vsim-SDF-3262) E:/verilog_test/ibm/filter_icc.sdf(121508): Failed to find matching specify timing constraint.
# ** Warning: (vsim-3448) E:/verilog_test/ibm/filter_icc.sdf(121528): Setting negative specify check constraint (-9 ps) to zero.
# ** Warning: (vsim-3448) E:/verilog_test/ibm/filter_icc.sdf(121529): Setting negative specify check constraint (-107 ps) to zero
GMT+8, 2025-12-26 16:28 , Processed in 0.010101 second(s), 3 queries , Gzip On, Redis On.
