查看: 3651|回复: 2
[讨论] 34362625, QQ group "Analog IC, We Can Do"
发表于 2011-4-17 00:50:39 | 显示全部楼层 |阅读模式
If you're a junior and enthusiastic Analog IC designer, it is the right platform for you to find your potentials;
If you're a senior Analog IC designer, it is the right platform for you to exert your talents;
If you're an expertise in Anlaog IC design, it is the right platform for you to offer the crucial directions to the greenhands.
Anyway, let's together completely discover the myths behind the Analog IC Design !!!
发表于 2011-4-23 12:05:23 | 显示全部楼层
发表于 2011-4-23 12:06:48 | 显示全部楼层
GMT+8, 2025-12-20 23:32 , Processed in 0.020464 second(s), 5 queries , Gzip On, Redis On.
