查看: 14769|回复: 35
[资料] [ebook]Nanoscale MOS Transistors: Semi-Classical Transport and Applications
发表于 2011-4-16 12:15:25 | 显示全部楼层 |阅读模式
by:  [size=90%]David Esseni, Pierpaolo Palestri, Luca Selmi
Title: Nanoscale MOS Transistors: Semi-Classical Transport and Applications
Author(s): David Esseni, Pierpaolo Palestri, Luca Selmi
Publisher: Cambridge University Press
Year: 2011
Written from an engineering standpoint, this book provides the theoretical background and physical insight needed to understand new and future developments in the modeling and design of n- and p-MOS nanoscale transistors. A wealth of applications, illustrations and examples connect the methods described to all the latest issues in nanoscale MOSFET design. Key areas covered include: \u2022 Transport in arbitrary crystal orientations and strain conditions, and new channel and gate stack materials \u2022 All the relevant transport regimes, ranging from low field mobility to quasi-ballistic transport, described using a single modeling framework \u2022 Predictive capabilities of device models, discussed with systematic comparisons to experimental results<\/p> 385380.jpg
Nanoscale_MOS_Transistors__Semi_Classical_Transport_and_Applications.pdf
3.71 MB, 下载次数: 321 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-4-16 12:24:59 | 显示全部楼层
New book, thanks for sharing!
发表于 2011-4-16 15:17:24 | 显示全部楼层
很新啊,谢谢楼主
发表于 2011-4-16 17:46:43 | 显示全部楼层
Thanks!
发表于 2011-4-17 20:54:05 | 显示全部楼层
thanks a lot for sharing
发表于 2011-4-18 09:08:41 | 显示全部楼层
非常感谢
发表于 2011-4-19 23:38:41 | 显示全部楼层
thanks for sharing
发表于 2011-4-20 18:13:38 | 显示全部楼层
Thanks a lot for your sharing !!!
发表于 2011-4-21 13:33:32 | 显示全部楼层
goooooooooooooooooooooood
发表于 2011-4-21 13:52:56 | 显示全部楼层
下來看看
GMT+8, 2025-12-25 17:40 , Processed in 0.023690 second(s), 6 queries , Gzip On, Redis On.
