查看: 15252|回复: 36
[原创] ARM1176 IEM Low-Power Guide 2009
发表于 2011-4-12 15:37:13 | 显示全部楼层 |阅读模式
Foreword
Preface
Acknowledgements
References and Bibliography
Low-Power Links
    Power Forward Initiative
    Cadence Low-Power Links
CPF Terminology Glossary
    Design Objects
    CPF Objects
Special Library Cells for Power Management
Introduction to Low Power
    Low Power Today
    Power Management
    Complete Low-Power RTL-to-GDSII Flow Using CPF
    A Holistic Approach to Low-Power Intent
    Verification of Low-Power Intent with CPF
    Power Intent Validation
    Low-Power Verification
    CPF Verification Summary
Front-End Design with CPF
    Architectural Exploration
    Synthesis Low-Power Optimization
    Automated Power Reduction in Synthesis
    CPF-Powered Reduction in Synthesis
    Simulation for Power Estimation
    CPF Synthesis Summary
Power-Aware Design for Test (DFT)
    Power Domain-Aware DFT
    Power-Aware Test
    CPF Test Summary
Low-Power Implementation with CPF
    Introduction to Low-Power Implementation
    Gate-Level Optimization in Power-Aware Physical Synthesis
    Clock Gating in Power-Aware Physical Synthesis
    Multi-Vth Optimization in Power-Aware Physical Synthesis
    Multiple Supply Voltage (MSV) in Power-Aware Physical Synthesis
    Power Shut-Off (PSO) in Power-Aware Physical Synthesis
    Dynamic Voltage/Frequency Scaling (DVFS) Implementation
    Substrate Biasing Implementation
    Diffusion Biasing
    CPF Implementation Summary
ARC Energy PRO: Technology for Active Power Management
    Overview of ARC Energy PRO
    The Power Struggle
    Designing Low-Power Solutions
    Project Subsystem: ARC CPU with Co-Processor
    Conclusion
NEC Electronics: Integrating Power Awareness in SoC Design with CPF
    NEC Electronics and CPF
    Why Low Power?
    Comprehensive Approach to Low Power
    Example of Mobile Phone System SoC
    NEC Electronics CPF Proof-Point Project: NEC-PPP
    Summary
Fujitsu: CPF in the Low-Power Design Reference Flow
    Fujitsu and CPF
    Low-Power Design Techniques Used by Fujitsu
    Low-Power Test Chip Developed with CPF
    Low-Power Design Flow with CPF
    Review of Low-Power Test Chip Design
    Fujitsu Reference Design Flow 3.0: Low Power with CPF
    Fujitsu's CPF Low-Power RDF Methodology
    Summary
NXP User Experience: Complex SoC Implementation with CPF
    Low Power is Critical to NXP
    CPF in Action on a Complex SoC Platform
    Power Network Intent
    Hierarchical Support for IP and Design Reuse
    Scalable Implementation
    DFT Impact
    CPF-Based Results
Freescale: Wireless Low-Power Design and Verification with CPF
    Business Implications of Power
    Wireless Carriers and Power
    Phone Power and Energy
    Active Power Challenge and Design Techniques
    Low-Power Design Methodology and CPF
    Mobile Application Power Reduction Results
    Summary
TSMC: Advanced Design for Low Power at 65nm and Below
    TSMC 65nm Low-Power Process
    CPF: The Low-Power Standard
    The TSMC Proof-Point Project
    CPF-Based TSMC Reference Flow 9.0.
    TSMC Low-Power Library: CPF Compliant
    Summary
ARM: 1176 IEM Reference Methodology
    Introduction
    ARM-Cadence Implementation Reference Methodologies
    ARM1176 Processor
    ARM1176JZF-S Low-Power Reference Methodology
    Conclusion
Faraday: CPF-Based Low-Power Design Methodology for Platform-Based SoCs
    Faraday Design Services and Low-Power Design
    Introduction
    Faraday CPF Flow
    Faraday So Compiler CPF-Enabled Platform-Based Design for Low-Power
    A Low-Power Platform-Based Design Example
    Faraday CPF Low-Power SoCompiler Design Methodology Summary
Sequence Design: Early Power Analysis with CPF
    Design for Power
    Nano CPU Design Overview
    Conclusions
ARM Cortex iRM: CPF-Driven Low-Power Functionality in a High-Performance Design Flow
    ARM and Cadence Collaboration
    iRM Flow Setups: Adding Low-Power Functionality to a High-Performance Design Flow
    Other Low-Power Functionality Additions to a High-Performance Design Flow
    Conclusions and Availability of ARM/Cadence iRMs
When Do You Know You Have Saved Enough Power?
    Impact of Low-Power Design
    Power Dissipation
    Static Power Optimization
    Dynamic Power Optimization
    ARM Intelligent Energy Manager™(IEM)
    Power Savings in Multicore Processors
    Conclusions
AMD: Power Gating in a High-Performance GPU
    AMD and Low Power
    Front-End Low-Power Logical Design/Verification Flow and Methodology
    Back-End Low-Power Physical Design/Verification Flow and Methodology
    CPF and Results
    Summary of Results
ARM 1176-JZFS CPU-Based Low-Power Subsystem:
Methodology to Reduce Electrical and Functional Failure in a Low-Power Design
    Abstract
    Overview of Ulterior Project
    Ulterior Implementation
    Assembly and Packaging
    Ulterior Implementation Results
Sonics: CPF Flow for Highly-Configurable On-Chip Network IP
    Overview
    Sonic Power Management Features
    CPF Generation and Automation
    Sample SoC Design
    Sonics CPF-based Low-Power Flow
    Low-Power Reference Flow and Tools
    Conclusion
Virage Logic: Minimizing Design Complexity with Power-Optimized Physical IP
    Virage Logic IP Portfolio
    Economics of Battery Life
    Economics of IC Cooling
    Low Power Design Solutions
    Virage Logic Power-Optimization Kit: Standard Cell Set
    Standard Cell in the Power Optimization Kit
    Using Library CPF for Level Shifters, Retention Flops and Power Switches
    40nm SiWare Memory Performance/Power Tradeoffs for Bank and Column Mux
    Summary
ARM1176_IEM_LPG_2009_part01.rar
14.03 MB, 下载次数: 348 , 下载积分: 资产 -5 信元, 下载支出 5 信元
ARM1176_IEM_LPG_2009_part02.rar
2.59 MB, 下载次数: 248 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-4-13 11:07:12 | 显示全部楼层
好东西啊,赞一个!谢谢楼主分享!
发表于 2011-4-13 13:11:29 | 显示全部楼层
thanks
for
shraing
发表于 2011-4-13 13:33:31 | 显示全部楼层
楼主 貌似少了5,6,7,9 。。。。
发表于 2011-4-17 20:38:03 | 显示全部楼层
thanks
发表于 2011-4-27 16:02:47 | 显示全部楼层
一定要好好学习一下。
发表于 2011-9-20 13:49:53 | 显示全部楼层
ttttttttttttttttttttt
发表于 2011-9-20 13:57:05 | 显示全部楼层
回复 1# amonghsh006
    yyyyyyyyyyyyyyyyyyy
发表于 2011-9-22 13:51:20 | 显示全部楼层
good data
发表于 2011-11-29 21:22:44 | 显示全部楼层
下下来看看!
GMT+8, 2025-12-16 06:02 , Processed in 0.019606 second(s), 4 queries , Gzip On, Redis On.
